Help identify 486 VLB motherboard
Reply 20 of 27, by Horun
Rauli wrote on 2015-11-22, 14:07:
Hi, I've just got one board like yours today. It's not in very good condition, but I will try to use it.
Did you manage to identify the board? Did you install a voltage regulator (which one) for 3V CPUs?
evasive wrote on 2020-05-02, 18:51:
Based on the "001519" in the bios string this was made by Epox. Is there a marking GXA486*** something on the board?
Good luck getting an answer:
Rauli - Offline
Last active: 2015-12-03, 12:48
Reply 23 of 27, by evasive
jexus_ wrote on 2020-10-14, 05:44:
evasive wrote on 2020-05-03, 18:31:
🤣 yeah sorry. I am binge-ID'ing motherboards at the moment...
i'm stuck with the same mobo too
Then I can ask the same question: Is there a marking GXA486*** something on the board somewhere? Are there any other markings? Can you put a high-res picture of the board online somewhere and link to it?
Reply 24 of 27, by Horun
I do not think it is a GXA486 variant (but could be) due to most GXA486 variants had PCI slots near the memory slots which this does not.
It could be a very early version of the GXA486 but finding any docs will be hard, Unfortunately most of the Epox 486 board docs are long gone.
Reply 25 of 27, by jexus_
evasive wrote on 2020-10-17, 21:00:
no markings at all
Reply 26 of 27, by Murugan
Recently found this board in a working 486 I picked up
No markings like that indeed but since it's disassembled ATM I'll have a better look tomorrow if someone is still interested.
