DirectX 9.0c build
Reply 60 of 73, by squareguy
ran across this by the way, haven't really looked into if the info was totally correct on driver versions for GTX 285.
https://forums.geforce.com/default/topic/6806 … r-for-gtx-285-/
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 61 of 73, by Skyscraper
Im using driver 186.18, I do not really remember why. Im the "if it isnt broken dont fix it" kind of guy when it comes to old video drivers. 😀
Reply 63 of 73, by squareguy
I wasnt thinking. Some things were fast and things like unzipping a file with windows explorer were strangely slow. The drive has 4k sectors so I guess I have to align it and reinstall.
Anyways, here is a screenshot of Far Cry showing environment reflecting in water.
1.28 MiB
Windows 98 SE
Reply 64 of 73, by PhilsComputerLab
What drive do you have?
WD has a free alignment tool. Never used, so if you have a WD, here's your chance 😀
Paragon, or some other mob, sells an alignment tool.
If you re-install, all you need to do is take the drive to another machine and partition and format it there. Then put it back in the XP machine.
Seagate drives have some built-in anti alignment slow down feature. At least that's what they claim 🤣
YouTube, Facebook, Website
Reply 65 of 73, by squareguy
Phil it is a Seagate drive. I will try to find something to align it instead of using its builtin slowdown-on-the-fly translation
I am going to create a new XP install CD with these 3 driver packs
DP_Chipset_wnt5_x86-32_1209
DP_MassStorage_wnt5_x86-32_1209
DP_LAN_wnt5_x86-32_1205
http://driverpacks.net/docs/beginners-guide-windows-xp
Windows 98 SE
Reply 66 of 73, by squareguy
I think I am gonna go find a large 512k sector hard drive to test with
the cd with driver packs for chipset, lan and sata worked very well
I also think I will use an audigy 2 sound card instead of the x-fi
Windows 98 SE
Reply 67 of 73, by KT7AGuy
Make sure it's an actual SB0350, if you decide to get an Audigy 2 ZS. There are a few variants that don't play well with the Creative Labs driver/software disc.
If anybody likes, I am happy to post my methods for getting both the SB0350 and SB0358 working.
Reply 68 of 73, by PhilsComputerLab
http://www.seagate.com/docs/pdf/whitepaper/mb … hnology_faq.pdf
Check if your drives supports this. But yea, easiest to partition and format in Vista+.
Reply 69 of 73, by squareguy
Putting in a WD Black 1TB drive and will align it and see how that goes.
Windows 98 SE
Reply 70 of 73, by squareguy
Everything looks good so far, need some time to play with it.
Took out X-Fi, installed SB0350 Audigy 2.
What Audigy 2 card is recommended to use with the 5-1/4" Bay addon SB0250?
Windows 98 SE
Reply 71 of 73, by squareguy
I think I am going to upgrade CPU to an i5-3570k to push this thing and give more options in case I decide to do something different with machine.
Liking it so far, more to come.
Windows 98 SE
Reply 72 of 73, by squareguy
I will compare my new DirectX 9.0 Box to the following article.
Tom's Hardware 3DMark06 article 'Best Of The Best: High-End Graphics Card Roundup' May, 2009
http://www.tomshardware.com/reviews/radeon-ge … up,2297-16.html
Tom's stock Nvidia GTX 285
I did not see which driver version they were using.
1280x1024, Default Quality
3DMark06 v1.1.0 SM2.0 Score 8397
3DMark06 v1.1.0 HDR/SM3.0 Score 8964
3DMark06 v1.1.0 3DMark Score 20638
CPU Score between 6317 and 6680, they were using an i7-920 overclocked to 3.8-GHz.
My System stock Nvidia GTX 285
GeForce 196.21 drivers.
3DMark06 v1.2.0 SM2.0 Score 7068
3DMark06 v1.2.0 HDR/SM3.0 Score 7988
3DMark06 v1.2.0 3DMark Score 15014
CPU Score 2799 Celeron G1610 @ 2.6-GHz (stock speed)
Thoughts
Tom used 3DMark06 1.1.0 and I used 1.2.0 from 3DMark's website, hopefully they produce almost identical scores.
You can clearly see all I am missing is some CPU power to push this thing to the max.
Going from a Celeron G1610 @ 2.6-GHz to an i5-3570k @ 3.4-GHz will give me an instant ~30% increase in CPU power. That doesn't even take into account the extra cache, 3.8-GHz Turbo, or the extra 2 cores. The i5-3570k CPU seems like the one to get if I am going to spend any money on a different CPU as it smokes the other 1155 CPU's and it doesn't cost much more on the used market. It seems there are some games that can make use of a quad core and if I ever decide to do something else with this box I will not be looking to upgrade the CPU yet again.
I am going to install Nvidia GeForce 296.10 drivers, reboot, run another test and post those scores as well just to see if there is a difference.
Windows 98 SE
Reply 73 of 73, by squareguy
296.10 Drivers
A slight difference, all within the margin of error.
GeForce 296.10 drivers.
3DMark06 v1.2.0 SM2.0 Score 7122
3DMark06 v1.2.0 HDR/SM3.0 Score 8131
3DMark06 v1.2.0 3DMark Score 15189
CPU Score 2823 Celeron G1610 @ 2.6-GHz (stock speed)
With a i5-3570k (at stock speed) I believe I will easily blow right past a 3DMark Score of 20000.
Windows 98 SE
