Reply 520 of 744, by gerwin
- l33t
wrote:Here's a SysEx file that does just the above:
Neat! it works.
I will try to understand what exactly you did there later...
wrote:@Edit: For proper CM-64 instrument display on SC-VA you have to set SC-55 mode before sending the CM-64 mode SysEx. In other modes the mapping is set correctly but you will get '-----' as instrument name on all channels.
I noticed you have to set SC-55 in Options->System->Map-Mode in this case. I found the GS Reset on the start of your SysEx file prevents the chaining with my earlier files, I replaced the Reset with the SC55Mode SysEx commands. Then it works regardless of what the option screen says. 😀 (Attached)
I am wondering whether I should edit the files I attached, to add a GS Reset in front. I don't like midi-songs doing a Reset by themselves, but these are not songs...
