Best WinXP Video Card
Reply 320 of 342, by pilipali
God Of Gaming wrote on 2024-12-24, 07:24:
However if you have both a win98 retro gaming PC and a winXP retro gaming PC, probably makes more sense to install those dx5-6 games on the win98 pc, and not downgrade the winXP PC to an older slower graphics card just to gain compatibility for them?
i never want to revisit win9x ever again.
nothing but bad memories of random crashing and stuff
to me it seems like a modern pc with win11 + dgvoodoo2 might just be the best pc for win98 era games
Reply 321 of 342, by RetroPCCupboard
pilipali wrote on 2024-12-28, 14:28:
I think the situation is different now. With a PC in the 90s, you probably installed a whole load of things, used early buggy drivers, and maybe tweaked hardware often and updated the OS frequently. These days you can choose a known good combination of hardware and drivers, install Service Pack 3, and then enjoy your games. I have mostly had trouble-free experience with Win9x OS stability in my Retro builds.
Reply 322 of 342, by Joseph_Joestar
RetroPCCupboard wrote on 2024-12-28, 14:55:
No.
If anything, this so called "unofficial service pack for Win98" will cause a slew of problems while solving nothing. Do a forum search on that and see what comes up.
My retro stuff
Reply 323 of 342, by RetroPCCupboard
Joseph_Joestar wrote on 2024-12-28, 15:01:
No.
Fair enough. I have only noticed one issue, which is that folders default to a blank Web view. Easy enough to fix that. But, yeah, use an official service pack if you prefer
Reply 324 of 342, by nd22
The Serpent Rider wrote on 2024-12-24, 20:15:
GTX 285 renders Crysis below 30 fps in some heavy scenes.
GTX 580 lightning from MSI renders Crysis under 30 FPS on the snow level and the last level at 1080 max settings including AA! GtX 780TI is the first card I personally played with that renders Crysis at 60FPS average at 1080p maxed out on those levels!
Reply 325 of 342, by RetroPCCupboard
nd22 wrote on 2025-01-14, 11:20:
I plan to play Crysis on my 980 Ti, 3770k, X-Fi build under Windows 7. Hopefully at 1440p. I've not played Crysis beyond the first 30 mins or so into the game. Are games that can use DirectX 10 really considered XP games? It's fun to test them, just to see how it does, but I think it can't be the best way to play the game.
For me an XP build should be able to cope with games like Elder Scrolls Oblivion, Halflife 2, F.E.A.R, Splinter Cell: Chaos Theory, Quake 4, DOOM3, Age of Empires III, Prince of Persia (Sands of Time, Warrior within and Two Thrones), UT 2004, FarCry, Sims 2.... etc.
Maybe those games are not on everyone's lists. But for me, those are games I played in the past and want to again.
Ideally I also want to play Metal Gear Solid 2 Substance, but that's a very fussy game. I think I've only managed to get it to work on Geforce 4600... Possibly the 6800 as well, but can't remember.
Reply 326 of 342, by ubertrout
RetroPCCupboard wrote on 2025-01-14, 12:20:
I plan to play Crysis on my 980 Ti, 3770k, X-Fi build under Windows 7. Hopefully at 1440p. I've not played Crysis beyond the f […]
Using a i5-4690 (non-k) and GTX 960 I was able to get 100 FPS in Crysis pretty consistently at 1080p high settings. Although Max settings in theory only work in Vista and higher it's pretty easy to enable them - but I only learned that after finishing the game. You can also enable hardware EAX using a pretty simple tweak to the ini file. The only exception is the Ascension level, where even on that system it chugged into the 30s - I'd strongly recommend using the patch for that level.
It doesn't break a sweat in any of those other games, and yours definitely won't. I don't know about Metal Gear 2, kind of curious to try it on my 7900 GS.
Reply 327 of 342, by God Of Gaming
ubertrout wrote on 2025-01-15, 20:13:
How exactly? Last I was looking into this it was using some form of software eax over fmod and I couldnt find a way to switch to proper directsound3d
Reply 328 of 342, by RetroPCCupboard
God Of Gaming wrote on 2025-01-17, 11:46:
I assume its this:
https://www.reddit.com/r/Crysis/comments/1evh … inxp/?rdt=61792
I haven't tried though.
Reply 329 of 342, by AlexZ
I found out GeForce GTX 480 has issues when playing DirectX 8.1 games such as Need for Speed Hot Pursuit 2 on Athlon 64 3400+. There is a major FPS drop over GeForce 9800 GT using the same driver version (260.89) making the game unplayable. There are also graphical glitches like billinear filtering missing in some parts of the road. The filtering issue gets fixed in 306.81 but performance issue does not.
If you would like to cover DirectX 8.1 games accurately as well then stay away from the new cards like GTX 480 and later.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 330 of 342, by Joseph_Joestar
AlexZ wrote on 2025-02-28, 13:07:
I just tried NFSHP2 on my i5 3570K + GTX 970 rig using 355.98 drivers under WinXP. On that setup, I'm getting 300+ FPS at 1600x1200 with all in-game setting maxed and V-Sync turned off. With V-Sync turned on and 8xSGSSAA forced via Nvidia Profile Inspector, I get a locked 60 FPS and less than 30% GPU utilization.
The attachment NFSHP2_SGSSAA.jpg is no longer available
I don't think it's good to generalize like that based on one problematic game. I've tried several other DirectX 8.1 titles (e.g. Unreal 2, WarCraft 3 and Morrowind) on the system mentioned above, and they all worked properly.
My retro stuff
Reply 331 of 342, by AlexZ
There is definitely some kind of emulation going on on GTX 480 as opposed to 9800 GT. Maybe because your GPU and CPU is much faster it isn't noticable.
Reply 332 of 342, by Dimos
Enabling the "very high" graphics options for Crysis through modified config files on Windows XP (dx 9) was a very simple task. The game is actually running better on dx 9 than dx 10 mode and the image quality is literally indistinguishable between them. To be honest modifying the configs seems mandatory for at least a decade now (with the hardware options being able to max it out being easily available) cause you can tweak the game to look even better than the "very high" settings.
Also a very important detail for anybody interested: enabling Transparency Anti Aliasing through Nvidia control panel or Nvidia Inspector together with the in-game msaa makes the game look phenomenal even by today's standards. This way you can eliminate all the Aliasing that the ample vegetation of the game has together with msaa that doesn't fix this issue. Mind you that this is a pretty taxing procedure though, so you really need a gtx 780, Titan, 780 ti, Titan Black, 970, 980, 980 ti, Titan X to do that and maintain consistent high framerate.
With my Gtx 970 and i5-3570k (using modified -beyond very high- configs and 8xMsaa in conjunction with 8xTrssaa) i get 57 fps in the gpu benchmark and almost 62 fps in the cpu benchmark.
Cpu: Intel i7 4790k
Gpu: Gigabyte Xtreme Gaming 980 ti
Ram: G-Skill Trident X F3-2400C10Q-16GTD
Mobo: Gigabyte Z97x Gaming 5
Hdd: T-Force Vulcan Z 512 gb Ssd
Psu: Corsair CX650
Soundcard: Creative SB Audigy RX
Os: Windows XP Sp3 x86
Reply 333 of 342, by ubertrout
Dimos wrote on 2025-03-19, 11:26:
Curious to try this! I only have a 960 in mine but it's currently on a CRT which tops out at 1280x1024 so it might be doable.
Reply 334 of 342, by Dimos
At that resolution it's definitely doable. For a brief time period (a couple of months actually), i had an Asus Strix 960 installed in my rig and with exactly the same settings, with 4xmsaa and 8xTrssaa at 1920x1080, the same benchmarks gave me around 54 fps. So in your case you might hit almost 60fps.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 335 of 342, by Dimos
I also wonder if anyone here has a Quadro M6000. I know it works with the usual driver inf mod as the other Maxwell gpus and from a brief look at some gaming benchmarks from that time it seems that it performs (almost) on par with the Titan X and that was with the Quadro drivers, which of course are not optimized for gaming, rather than workstation work, which after all is the purpose of the Quadro series of cards. It would be very interesting to learn if anyone has ever tried this card with XP for the purpose of also gaming with it and what was the outcome.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 336 of 342, by myne
https://m.youtube.com/watch?v=HIzFAfK17G4
I don't see why xp would be much different if the drivers load.
I built:
Reply 337 of 342, by Dimos
It wouldn't. The Quadro is expected to be more than capable in gaming situations, although not oriented towards that, the real question is how it performs compared to the 980ti and the Titan X and also how it would perform with the modded Geforce drivers compared to the (workstation oriented) Quadro drivers. I 've read somewhere that if you tried to install (original, unmodded) Geforce drivers with a Quadro card then it is automatically recognised as a Quadro one and instead the Quadro drivers get installed somehow. But since we are talking about modded drivers with XP, then the Geforce (gaming oriented) drivers should be installed. As i said before i remember some (not very extensive) gaming benchmarks that showed an M6000 Quadro performing (almost) equally with the Titan X. That was with the Quadro drivers of course. So with the Geforce ones, what would be the outcome? If anybody here has/had an M6000 and used it for gaming purposes on XP, then i 'd really like to give us some info.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 338 of 342, by cyclone3d
Per the specs, the Quadro 6000 should be just about the same. I'm basing this off of techpowerup.
However, my Titan X is reporting clocks of I think 1372 1392 for the GPU during benching while techpowerup says that the max boost clock is 1089.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 339 of 342, by Dimos
The boost clock that gets reported for each retail board of a gpu is the minimum, guaranteed, frequency that the specific board will reach when the boost clock is activated. Depending on thermals, silicon lottery etc. that frequency could be a little above that or much higher.
Cpu: Intel i7 4790k
Psu: Corsair CX650
