How about a MR-BIOS ROM file repository?
Getting old software/games running on older hardware.
Re: How about a MR-BIOS ROM file repository?
Postby Deksor » 2019-3-11 @ 16:11
Deksor
Postby Cyrix200+ » 2019-4-23 @ 19:01
I was digging through some boxes of junk I bought in the last few years, and I found this MR BIOS chip.
I have a MiniPro, but how do I find the correct chip type without removing the sticker?
Print on the bottom says 7138179BBA PHILIPPINES UX 50
User avatar
Cyrix200+
Postby keropi » 2019-4-23 @ 19:56
read it as generic 27C512 it should do the trick
User avatar
keropi
Postby Cyrix200+ » 2019-4-23 @ 20:58
keropi wrote:read it as generic 27C512 it should do the trick
So the software doesn't have a generic 27C512 option. I had tried a few already, but those didn't work. Then I selected OKI MSM27C512 and it worked!
Seems to be the "MR BIOS (tm) Copyright (c) 1992, Microid Research Ver V1.28 Port OPTI33" (Not sure if the 33 is part of the string) dated 01/15/92
User avatar
Cyrix200+
Postby keropi » 2019-4-23 @ 21:34
a trick to remember, chose whatever 27C512 chip you want but uncheck the "Check ID" tickbox on lower left corner of the program - then it will work
Basically the programmer won't check if it's a TI, OKI, AMD, whatever manufacturer and just dump the data
User avatar
keropi
Postby rmay635703 » 2019-4-24 @ 01:34
I had always hoped for bios upgrades for name brand machines like the Tandy 1000 Rex or ast advantage adventure 4/66d
Ah well
User avatar
rmay635703
Postby Moogle! » 2019-4-26 @ 06:01
Aren't 386 BIOSes usually 32K?
You may to dump it as a 27c256, using the above mentioned methods. Wouldn't hurt to try both, I don't think.
Moogle!
Postby bjwil1991 » 2019-4-26 @ 06:58
Depends on the motherboard. Some were 64KB in size, others were 32KB.
Systems from C64 to FX-6300.
User avatar
bjwil1991
Postby maxtherabbit » 2019-5-01 @ 14:42
what's the rundown on >502MB support with Mr BIOS? did the 386 BIOSes have any translation support?
User avatar
maxtherabbit
Postby Hinoserm » 2019-6-27 @ 05:07
Signed up specifically to post this since I wasn't sure how to share the info otherwise.
Not sure if this one has already been found, but I recently found a MR BIOS chip on a motherboard marked SM 486-50USC. This board has a UMC UM82C491F chipset. The MR BIOS ROM chip is hand-marked 1150USC. The boot screen shows it to be MR BIOS V1.50.
You can grab a copy from the URL below. I would suggest if possible someone set up a mirror or upload it to the relevant archive. Included in the zip file are .bin and .hex files as well as photos of the board and chip. The chip is some version of 27c512.
http://otis.io/misc/mrbios_um82c492f_1150usc.zip
Hinoserm
Postby keropi » 2019-7-03 @ 15:27
Hinoserm wrote:Signed up specifically to post this since I wasn't sure how to share the info otherwise.
mirrored the bios file locally
(1.58 MiB) Downloaded 6 times
User avatar
keropi
Postby Black6spdZ » 2019-7-16 @ 01:37
Miasmark wrote:I believe the Spectra Utilities disk contains most of the socket 5/7 bioses. and award bioses
http://www.vogonsdrivers.com/getfile.ph ... state=54,0
I can't tell exactly which one is which since they are listed by numbers. likely have to boot the "Install disk" to see if the cd has a bios first. then you use the utility in windows to copy it to the floppy and then boot the floppy again to use it. Tested on a PB 640 and Advanced EV motherboard and both ended up with MR BIOS 3.46.
Im also curious what the differnce in the different versions of the disk are. since I have V1 of the cd.
Do you know what the Windows CD installer renames the bios image to before it copies it to the diskette? I cannot get the setup to work through an XP VM and USB floppy. I know the Mr Bios filename for my particular mobo "PB 680 Orlando" but it wont see the floppy correctly to transfer it over.
Black6spdZ
Postby obitus1990 » 2019-8-31 @ 03:29
Does anyone have an MR-BIOS for the Contaq 82C596A chipset for 486 motherboards?
User avatar
obitus1990
Previous
Return to Software
Who is online
