Reply 40 of 68, by Deunan
TAG chip can be either 8k or 32k SRAM, some boards have switches for that as well and/or expect the TAG to be matched to the cache size. But for 256k it should be 32k anyway.
Regarding the burned trace, it goes to the 33ohm resistor near the upper UMC chip, correct? In that case the resistor is a line terminator to improve switching transients, and the other side of it should be connected directly to big chip. In this particular case it goes to a via so that connection is either on the other side or inside (inner layers) of the PCB.
As you can see pretty much all of the signals to SIMM slots are done like that, so you can:
1) find which pin on the UMC chip that one goes to, exactly
2) compare the resistance of this connection to SIMM vs several other ones (pick at random), you should get similar results of about 33 ohms
If you get considerably different values it's worth investigating why.
