Acronis Alternatives?
Announcements, advice, random banter, unrelated discussion, et cetera.
Postby tincup » 2019-1-13 @ 23:16
I upgraded to W10 a few months ago. I'm very pleased with the new system with one caveat - I had to move on from the W7 iterations of Acronis Home Image to the most recent AHI-2019. I'm not at all happy with it's super confusing/opaque functionality.
Anyone out there use a comparable suite that lets you do a simple operation like: select target partition(s), name the image, select where it's to be stored?
Believe it or not by AHI now makes this ridiculously trick to do - and doesn't really do it. The Recovery software retain the simple interface and functionality of earlier Acronis iterations, but not the new suite.
User avatar
tincup
Re: Acronis Alternatives?
Postby Jo22 » 2019-1-14 @ 04:52
Oh, well that's sad. :(
We used Acronis at home since version 7 or so.
As a workaround, can you use the bootable media to create backups ?
Back then, when we had True Image 9 or 10, we often used the bootable media.
Years later, we even used the recovery media of version 2011 to restore backups created by older versions (9 etc),
because the old Linux kernals failed to work on the new machines (the one based on the DOS kernal still worked, but used slow BIOS routines).
User avatar
Jo22
Postby PC Hoarder Patrol » 2019-1-14 @ 05:08
User avatar
PC Hoarder Patrol
Postby CrossBow777 » 2019-1-14 @ 06:02
I've been quite pleased with Macrium lately for my backup and drive cloning purposes.
User avatar
CrossBow777
Postby oeuvre » 2019-1-14 @ 14:34
easeus todo backup works great but it's not free...
alternatively you can use clonezilla but it does not like cloning from larger drive/partition to smaller
NetVista Sleeper i7 3770, 16GB, GTX750, 2xSSD + HD, XP/7/MacOS 10.13.6
ThinkCentre Sleeper Ryzen 7 2700, 32GB, RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Postby tincup » 2019-1-14 @ 21:42
I might try Macrium again. My first pass was unpleasant, but neither is AHI so it's worth another look. At this point I'm not adverse to paying - so long as it's clear, simple and works. I've used Easeus utilities before and they worked pretty well - maybe they have a trial version.
Thanks all...
User avatar
tincup
Postby CrossBow777 » 2019-1-14 @ 23:44
Well..It was Macrium that finally let me take the data off an actual 1tb drive in my laptop and move it to a slightly smaller 960gb SSD. The data itself I knew would fit but acronis would have none of it. Macrium did it by imaging the partitions off the original as separate images and then restoring those to the actual newly made partitions on the new drive.
User avatar
CrossBow777
Return to Milliways
Who is online
Users browsing this forum: BLEXBot [Bot] and 3 guests
