Romance of the Three Kingdoms No Colour
Having problems with a specific game or application? Post your problems here!
Postby simoncwq » 2019-1-27 @ 15:16
I'm new to using dosbox and i was wondering if anyone encountered having no colour when running a game?
Basic info:
1. Asrock B450 Fatality K4
2. Ryzen 2600 (3.4-3.9Ghz)
3. 16GB DDR4 2666Mhz
4. Nvidia GTX1070Ti 16GB
5. None i guess?
6. Windows 10 Pro (Build 17134.523)
7. Romance of the Three Kingdoms II (DOS Version NOT SNES)
8. No colour on any screen, full black and white.
9. Always
10. Not sure (Default setting is used)
11. Opengl (Tried all but stuck with opengl)
12. Dosbox 0.74
13. Changed all outputs, machines in config. Updated graphic drivers and windows settings. Downloaded fresh rom and usable rom from other PC with colour.
(Other PC is running the game just fine but using AMD GPU instead)
Reference
The following are things that should be in your help request:
1. Motherboard
2. Processor type and speed
3. Amount and type of RAM
4. Video board w/ RAM amount and type
5. Sound board
6. Operating system
7. Game name (and version, if applicable)
8. Description of problem (be detailed: saying "it's jerky" doesn't help, saying "the player sprites seem to be jerky when I'm pressing any of the arrow keys" does)
9. Reproducibility of problem (always, only once, always but only on a specific level, etc.)
10. Sound mode used
11. Video mode (Software, OpenGL, Direct3D, or Glide, and resolution)
12. Version of emulator (for VDMSound, probably 2.0.4 or 2.1.0; for DOSBox, 0.58+)
13. Steps already attempted to solve the problem
simoncwq
Re: Romance of the Three Kingdoms No Colour
Postby red_avatar » 2019-2-08 @ 11:43
Very odd. Did you copy every single setting from your other PC? And using the exact same files for DOSBOX and inside DOSBOX to run the game?
Retro game fanatic.
IBM PS1 386SX25 - 4MB - 85MB HD
IBM Aptiva 486SX33 - 8MB - 270MB - SB16
IBM PC350 P233MMX - 64MB - 20GB - AWE64 - Voodoo2
PIII600 - 320MB - 120GB - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - 1TB - SB Audigy 2 - HD 4870
User avatar
red_avatar
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 0 guests
