Reply 20 of 25, by Dancsi40
Yeah, for Nocturne, without DgVoodoo 2, the videos play fine on Windows 10 with compatibility mode on (Windows 98/Me), but the max resolution you can get is 640x480
The DDraw.dll file causes the no intro/video problem, I just tested it. The other 3 files (D3D8.dll, D3D9.dll and D3DImm.dll) don't change anything, the videos will play but no higher resolution. As soon as you copy the DDraw.dll, no more videos but you can select higher resolutions.
