Maintaining original resolution in fullscreen?
General information and assistance with DOSBox.
Postby jez » 2019-3-10 @ 11:29
When I configure things thus:
Code: Select all
fullresolution      = desktop
windowresolution    = original
output              = surface
aspect    = false
scaler    = normal4x
DOSBox will scale the video to 4x both in windowed and fullscreen modes (in fullscreen mode you get letterboxing to achieve this).
However, when I change output from surface to any of the more modern outputs like ddraw or opengl, fullscreen mode always stretches the video to the resolution of my desktop. Is there any way I can get the 'surface' behaviour with one of the more modern output types?
== Jez ==
User avatar
jez
Re: Maintaining original resolution in fullscreen?
Postby jmarsh » 2019-3-12 @ 01:11
Change aspect to true.
jmarsh
Postby kjliew » 2019-3-12 @ 01:47
You probably also need to use an output that support hardware scaling, such as opengl, openglnb or ddraw, and disable the software scaling with "scaler=none". The "output=surface" does not support hardware scaling, and that will hurt performance with "aspect=true".
kjliew
Postby jez » 2019-3-12 @ 09:59
Eh? Did you even read what I posted? I said "output=surface" did achieve the output I wanted.
== Jez ==
User avatar
jez
Postby realnc » 2019-3-19 @ 08:18
I assume you want desktop resolution in fullscreen, but non-scaled output (meaning black borders around it.) I don't think there's a way to do it.
But you can try to set:
fullresolution = original
Which will probably not work well on modern displays. You'll get the nearest available resolution with some form of scaling applied by the display. You can probably fiddle in your monitor's OSD to find scaling settings. Or you can force GPU scaling in your driver control panel and try the scaling options offered there.
User avatar
realnc
Postby jmarsh » 2019-3-19 @ 10:49
realnc wrote:I assume you want desktop resolution in fullscreen, but non-scaled output (meaning black borders around it.) I don't think there's a way to do it.
Sure there is, set aspect to true.
jmarsh
Postby realnc » 2019-3-19 @ 11:05
Does not work. It still scales, just with the correct aspect ratio. Which is what one would expect just from that option's name.
The issue here is that when using anything other than surface, using "scaler = none" doesn't work. DOSBox will scale no matter what.
User avatar
realnc
Postby jmarsh » 2019-3-19 @ 12:21
Reading between the lines, OP wants aspect ratio correction ("fullscreen with letterboxing"). If surface already did exactly what he wanted why would he be asking for alternatives?
jmarsh
Postby jez » 2019-3-19 @ 12:53
No I didn't mention aspect ratio correction. I simply want the behaviour you get when you put output=surface in fullscreen - maintain the resolution output by the scaler and surround it in a letterbox - when you put output=opengl or similar.
== Jez ==
User avatar
jez
Return to DOSBox General
Who is online
Users browsing this forum: Google [Bot] and 1 guest
