DosFreak All System Specs 4-25-2025
Reply 60 of 71, by robertmo3
Seagate is now selling refurbished disk drives. It has set up an official storefront on eBay as a direct channel for consumers to access factory-certified hard drives as part of the Seagate Circularity Program. Seagate says it’s committed to enabling the secure reuse of storage devices and reducing hard drive shredding. Hard drive shredding entails breaking down a hard drive into tiny pieces so that data cannot be recovered. As rare earth materials contained in those parts cannot be reused, hard drive shredding harms the environment and is not sustainable.
https://www.ebay.com/sch/i.html?_dkr=1&iconV2 … ecerthdd&_oac=1
Reply 61 of 71, by DosFreak
Updated my main system.
Added B850M motherboard. (Replacing B650M)
Added AMD 9950x3d (Replacing 7950x)
Inverted the Sama IM01 case
The now bottom case fans were changed to intake
The rear fan was changed to exhaust
The CPU fans were changed to blow towards exhaust
The bottom intake fans blow upwards hitting the mobo, RAM, CPU fan intake and GPU.
I might have room to deshroud the GPU but I ran a test all night and GPU was steady at a constant 70c and the case is at my feet so noise isn't a thing so not much point.
MAIN SYSTEM
Case: SAMA IM01 $69.99 (Currently inverted)
Case feet: 4x Monosaudio 40x20mm Speaker Isolation Feet Speaker $15.50
PSU: Corsair SF750 750W $116.99
Motherboard: ASUS TUF Gaming B850M-PLUS WiFi AMD AM5 B850 mATX $240.89
Processor: AMD Ryzen 9 9950X3D 16-Core Processor$974.55
Processor cooler: Noctua NH-U12A $119.95
Memory: 1x G.SKILL Trident Z5 Neo Series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) $259.99
SSD: 2x SK hynix Platinum P41 2TB PCIe NVMe Gen4 M.2 $644.46
Fans:
REAR EXHAUST 1x Noctua NF-A9 PWM chromax.Black.swap, Premium Quiet Fan, 4-Pin (92mm, Black) $19.90
CPU TOWARDS EXHAUST 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
BOTTOM INTAKE 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
Video card: Geforce RTX 4080 16GB VENTUS 3X OC $1157.00
Monitor: LG 38GN95B 37.5" 3840x1600
Make your games work offline
Reply 62 of 71, by robertmo3
Benchmarking emulators on latest machines
would be great if you could add new entry to our database 😀
also if you could grab qemu from here
QEMU 7.1 3dfx Voodoo Glide
c:\test\cputest
and provide one more entry 😀
Reply 63 of 71, by DosFreak
I'll look through the thread.
FYI I don't use projects created\forked by banned users. My sanity is highly important to me.
So that leaves only two projects I can't\won't touch. I won't list them but one of them is the one you posted.
Reply 66 of 71, by DosFreak
Windows 11 24H2
DOSBox 0.74-3
core = dynamic
cycles = max
D1:
Microseconds one loop: 1.47
Drhystones/sec: 681576
VAX MIPS: 387.92
D2
Microseconds one loop: 1.49
Dhrystones/sec: 669456
VAX MIPS: 381.02
Reply 67 of 71, by DosFreak
Added Framework laptop to specs
Framework Laptop 13.5" w/ AMD Ryzen AI 300
Chipset: Ryzen AI 9 HX 370 w/Radeon 890M
Memory: Kingston FURY Impact 64GB 2x32GB 5600 MT/s
SSD: Samsung 990 PRO 4TB M.2 2280
Reply 68 of 71, by DosFreak
Been testing eGPU with my framework laptop as backup if my main desktop goes down or if I go somewhere and for some reason need a GPU (not likely) since all these GPUs do is gather dust until I use them for game testing.
Below was tested with Stalker 2:
Initially slapped a 7900xtx in there but my success rate with AMD and passthrough to VMs isn't great so expected the same and was disappointed as usual. 100% egpu usage and performance was about the same as the internal GPU which was sloooooooooooooooow.
Switched to a 3060 v2 which was much better but not for Stalker 2.
Switched to a 3080 and this was much better still slower than I expected so I assumed mabye it was the adapter card or TB3 but checking some benchmarks online this is roughly the performance of a 3080.......when I come down from my ivory tower where my 9950x3d w/ 4080 resides it's a bit of an adjustment. 😀
EGPU 3080
GIGABYTE Gaming OC GeForce RTX 3080 10GB GDDR6X PCI Express 4.0 ATX Video Card GV-N3080GAMING OC-10GD (rev. 2.0)
Adapter Cable 80cm Compatible with Thunderbolt 4 * 1
Adapter: JMT ADT-UT3G USB4.0 Docking Station 64G PCIe4.0x4 to Laptop Graphics Card External Conversion Adapter Compatible with Thunderbolt 3 4
Case: Fractal Design Ridge Black - PCIe 4.0 Riser Card Included - 2X 140mm PWM Aspect Fans Included - Type C USB - m-ITX
PSU: SilverStone SX1000 1000W SFX-L
Reply 69 of 71, by DosFreak
Added "PCIe 4.0 x4 to Oculink External SFF-8612 Adapter Card for eGPU Dock Mimi Pc" to each system in the op.
This replaces a previous Oculink card where the connection was internal with no bracket whereas this one is external with a bracket.
Also the Intel system didn't have a card where now it does for when I want to use a egpu with it.
Reply 70 of 71, by DosFreak
Purchased a Corsair SF1000 to replace the SF750 in my Sama IM01.
Purchased another Fractal Ridge case as a eGPU case. Stuffed the SF750 in there along with a Nvidia 3060 for 7+ compatibility testing.
Reply 71 of 71, by DosFreak
Figured out the issue with the slow 7900XTX as a eGPU with the Framework laptop.
I was testing without a power cable, plug it in and performance jumped up considerably.
Desktop level GPU performance with a laptop, crazy
