First post, by Stiletto
Just found out that the MIDI chip on the Monterey is emulated in MAME.
(ICS WaveFront 2115). It's still undergoing revisions, though, but you can hear it in MAME's emulation of the IGS PGM (Polygame Master) games (Dragon World II, Knights of Valour / Sangoku Senki, Knights of Valour Plus / Sangoku Senki Plus, Oriental Legend / Xi Yo Gi Shi Re Zuang)
Of course, there's also the matter of a huge Motorola 56001 DSP emulated, the firmware to be dumped (if it has some), ROMs, etc. etc.
Just thought you'd like to know.
(MT32 emulation first, plz! 😉 )
do the Fandango!" - Queen
Stiletto
Reply 2 of 16, by Stiletto
Snover wrote:
There are games that used a special TB MIDI chip? Hmm... I never saw any.
Not that I know of, but it's still an intriguing possibility - use VDMSound as a general soundcard emulation framework.
Another odd idea: could one emulate a soundcard using software and have it show up as a device in Windows 2000/XP Device Manager to be used? You'd think so, but I don't believe any third-party hacker has done it yet. 😀
Stiletto
Reply 6 of 16, by vladr
You get GUS emulation at http://listen.to/gusemu/ as standalone application. 😀
Nicht Sehr Gut wrote:
Me want Gravis Ultrasound in VDMSound.
Reply 7 of 16, by vladr
Can be done, though there aren't many soundcards left to emulate (that do anything fancier than SB, AdLib, etc... except for Tandy maybe but then trhe graphics get all screwed up with Sierra games).
Yes, can do it, that's how Windows' MIDI soft-synth works (though it interacts with the k-mode mixer directly I'm afraid). But you can easily write a driver that takes in the requests then passes them to a user-land process that can then use DirectSound and so on without messing with the k-mixer (kernel-mode sound mixer).
MT-32 update: just got an USB interface that I'll use to digitally record the MT-32 and even take a sneak preview at the ROM 😁 . Of course, it will be weeks before I can do anything with it because of work and so on, but hell, we're getting there! Should be able to achieve around 1MBps (around 250ksamples/second at 16-bit stereo, i.e. around 5x oversampling which is quite gewd!)
V.
Reply 8 of 16, by Nicht Sehr Gut
Smartypants. You know we discussed this before, his emulator is great, but apparently only for demos (as in hacker demos), not games. I've yet to hear of a single GUS game that worked with it. Can't you just swipe his code or something? Heh.
Reply 9 of 16, by vladr
Have you e-mailed him to ask him why GusEMU won't work with the games in question? He's a very nice guy, I'm sure he'll anwer you, if not ask me and I'll contact him (we kept in touch for a while). Beware, he may reply in German after seeing your alias, so make sure that the language of correspondence is established first. 😀
V.
Reply 10 of 16, by Nicht Sehr Gut
Finally broke down and mailed him. Just couldn't think of a casual way of saying "Hey could you make this thing compatible with every GUS game? Thanks."
Reply 11 of 16, by Snover
YEEEEEEEEEEEEEEEEAY!!!!!!!!!!!!
Yes, it’s my fault.
Reply 12 of 16, by Stiletto
Great. I was going through the same dilemma.
You may need to make a rough list of games that could use the GUS for him, we should start a separate thread for that.
I've been hoping that he'd give permission for GUSEmu to be integrated into VDMSound as a component, although it could still have its own separate identity as a system-wide thing. But that's for Vlad and him to hash out.
Stiletto
Reply 13 of 16, by Stiletto
Samples == bad if used IN simulation, but good if used to DERIVE emulation. But the best is when you have enough documentation and enough reverse-engineering of the silicon that you don't NEED samples if but to verify your emulation. That's what hanging around MAMEDEVs has taught me, at least. Have fun, Vlad. But I'd roll all the patches and updates into VDMSound 2.05 first, if I were you. Still, there's no reason why you couldn't work on both at once. 😀
Stiletto
Reply 14 of 16, by Stiletto
... Hm, I shall start a new list: "Cards to Emulate" 😉
...and other soft-synths. I just wondered if it would be "easier" than what VDMSound is currently doing.
Stiletto
Reply 15 of 16, by Nicht Sehr Gut
Stiletto wrote:
I've been hoping that he'd give permission for GUSEmu to be integrated into VDMSound as a component, ...
Reply received. Unfortunately,:
Most games use either the GUS MIDI, which is an emulation
requiring an TSR driver under DOS, or they use DMA for
uploading sample data to the GUS.
However, most games also use protected mode, and protected
mode DMA compatibility within a DOS box is not something
Windows (both 9s as well as NT) is good at.
We´re already in contact, both having the same problem.
A solution is not found yet, though.
Hrmm. There's got to be a GUS game somewhere that accesses the audio card like those demos do...
Reply 16 of 16, by Stiletto
Reply received. Unfortunately,: Most games use either the GUS MIDI, which is an emulation requiring an TSR driver under DOS, or […]
... ... ... it can't be impossible... ... ... 🙁
Stiletto
