First post, by ildonaldo
Hello,
I am looking for teh original drivers and software for the "VL System L.I.S 2 indicator" USB fan controller.
(here is a review with some pictures https://www.techpowerup.com/review/vlsystem-lis2/2.html
I found out that the display should work with "LCD Smartie" but I am looking for the retail software that came with the display.
The Software should be for Windows XP.
TNX & best wishes
Building my own PCs since 1991 - for my retro builds it's "no CF-disks, no Floppy emulators, no modern cases etc.", only the real and authentic stuff whenever possible/sensible/affordable.
Reply 1 of 8, by evasive
https://web.archive.org/web/20051124215226/ht … olCenter_EN.php
revision 2.2.2.2 is not available from there, maybe someone else has it.
https://web.archive.org/web/*/http://www.vlsy … .co.kr/pds/lis/*
Reply 2 of 8, by ildonaldo
evasive wrote on 2020-05-26, 20:43:
Don't know, both links on the wayback are dead links cause the URL doesn't exist any longer.
Is there any DL source that's still working?
Reply 3 of 8, by ildonaldo
Thanks to the links that evasive posted, I found out that I need the following two files:
a) Driver: http://www.vlsys.co.kr/pds/driver/USB1002154.zip
and
b) Software: http://www.vlsys.co.kr/pds/lis/MCC2222.exe
But I hadn't been able to find any working DL-Source so far - Please, can anybody help?!?
Maybe someone here has the original (Mini)CD that came with this display and can send me an image?
BTW, the whole thing looks like this:
39.52 KiB
Reply 4 of 8, by evasive
Driver is generic FTDI USB to serial according to this info:
https://forum.team-mediaportal.com/threads/lc … ort.1709/page-6
2.2.2.2 is not to be found anywhere, however the 2.0.0.3 version can be downloaded:
https://web.archive.org/web/20060114114634/ht … lis/MCC2003.exe
Reply 5 of 8, by ildonaldo
evasive wrote on 2020-05-28, 08:35:
Driver is generic FTDI USB to serial according to this info: https://forum.team-mediaportal.com/threads/lc … ort.1709/page-6 2.2 […]
Many thanks you for the links, they work fine.
But AFAIK I will still need the retail USB driver to set up the display properly or at leaste these drivers would make things easier.
I even had been able to unearth a Version 2.2.2.6 of the "Media Control Center" here:
https://l-i-s-indicator.software.informer.com/
... but sadly no USB drivers 🙁
Reply 6 of 8, by evasive
I have gone over the website once more and found listings for the LIS USB setup.zip and one more USB setup exe. Both contain generic FTDI USB-to-serial drivers. I fear for making things easier, the reviews of the CCM elsewhere do mention it is slightly buggy and the GUI feels a bit clunky. Others mention trouble getting the interface to WinAmp/Windows Media Player to work properly.
What OS are you using for this thing?
In case you want to contribute to linux support there is this project:
http://www.lcdproc.org/
Reply 7 of 8, by ildonaldo
evasive wrote on 2020-05-28, 13:01:
I intend to use it with Windows XP (for PC #3 of my sig).
Thank you for the effort, I will give the generic drivers a try.
I am just not shure if it will do the trick, because the L.I.S. 2 is not just a display, it's also works as fan control.
