First post, by Garrett W
- Member
That's tough if you try to recover the function of the card from that lousy image. I guess you don't have access to the hardware yet, so you won't be able to provide a better picture. Some things can be recovered from that image, though:
Too bad the chips further to the right, especially in columns with number below 33, are so dusty and/or out of focus that you can't make out any model numbers.
There is no conclusive evidence that the RCA-type jack is actually used for composite video - it might be anything. The card does not seem to be a video card, as it neither has an integrated CRTC or enough TTL chips to generate video timings. The 8051 is too expensive to substitute an CRTC like the 6845. So I guess the card interfaces some custom hardware.
^Great analysis IMHO 😎
I second, it's likely a special purpose board.
An RCA/Cinch/Phono plug could interface with about anything, not just composite.
Might be a signal generator, a form of digital multimeter etc. It could be anything, I'm afraid. 😅
Maybe the data in the EPROM chip contains a copyright string?
If so, this would provide further hints. 🙂
Yeah, I unfortunately don't have the hardware at hand yet and the seller wasn't too interested in cleaning things up and sending me clearer photos. Thanks for the analysis and assessment, this is interesting!
