Reply 60 of 72, by Verax
- Newbie
dataino.it wrote on 2021-07-19, 20:57:Verax wrote on 2021-07-19, 20:48:dataino.it wrote on 2021-07-19, 20:29:I finished testing the circuit and this is the schematic. I would say it works without problems. tomorrow if the heat permits I will do the version on a base (welding with 34 degrees centigrade is torture).
I was wrong to mark the two pins on the previous connection diagram and I corrected it in any case I republish it.
Cool! So it comes out the white wire connected to a resistance is the reset? (If i understand correctly?)
So you don't have any POST issues wit all of this? Like the keyboard is okay for you?Yes for start the computer manually u need to power on PSU (green cable connected to ground fixed ) and than the reset cable to ground for a little while .
OKay i'll try then 😀
