Reply 60 of 72, by Caluser2000
cyclone3d wrote on 2021-11-12, 15:31:
red-ray wrote on 2021-11-12, 12:42:
Errius wrote on 2021-11-12, 11:41:
Drives use megabytes
The Windows Properties panel reports my 255,266,258,560 byte drive as 237 MB rather than 255 MB, all in all it's a mess!
Drives are sold with the labeling of MB/GB/TB, hen in fact they are not. Then you also lose some space due to formatting.
If you look at the super fine print on the packaging, they state that they count a MB as 1,000,000 bytes instead of 1,048,576 bytes. All the mfgs should be sued for false advertising.
So you truly are the Big Rooster.
Reply 61 of 72, by red-ray
This is incorrect and/or misleading, check such as https://www.majordifferences.com/2018/03/diff … gabyte-and.html to confirm it's the case.
Reply 62 of 72, by weedeewee
If memory serves me, then some manufacturers also made the wonderful calculation of 1Gigabyte being 1048576000 😀 🤣
ie 1000 x 1024 x 1024
the good old days when such conversations about which was the correct number... meh
Giga Mega and Kilo are all defined as multiples of ten.
The fact that byte is added only matters to fanatical IT folks and bloody rotten marketing wankers.
Do not ask Why !
Reply 63 of 72, by cyclone3d
retardware wrote on 2021-11-12, 15:39:
Yes, even in Windows 10 you get strange values.
I guess this is from incorrectly converting forth and back with wrong factors several times.
255,266,258,560 Bytes converts to 237.7352291345596 Megabytes.
Yamaha YMF7x4 Guide
Reply 64 of 72, by red-ray
cyclone3d wrote on 2021-11-12, 16:37:
Incorrect again, 255,266,258,560 Bytes converts to 237.7352291345596 Mebibytes.
Reply 66 of 72, by cyclone3d
red-ray wrote on 2021-11-12, 16:43:
Gotcha.
It would be very interesting to see where the confusion started and who started it.
In that link, it states that MB can either be used for 1000 or 1024KB. Who thought that was a good idea?
Looks like up to 1998 there was no distinction and everything was MB.
43.71 KiB
73.36 KiB
80.24 KiB
Yamaha YMF7x4 Guide
Reply 67 of 72, by retardware
cyclone3d wrote on 2021-11-12, 17:13:
As far as I can remember, this was used by HDD manufacturers to blow up the megabyte count.
To solve the question one would have to find out when disks started to be advertised in "megabyte" capacity and then check when they started to count the millions instead of the 2^20....
Reply 68 of 72, by Errius
Bytes are useful for programmers. (At least in 8/16/32/64 bit architectures. 6/12/24 bit systems use 6-bit bytes instead.)
Does the end user need to use bytes at all though? On user-facing interfaces why not just reckon everything in bits?
“I like to dissect PCs. Don't you know I'm utterly insane?"
Reply 69 of 72, by weedeewee
Errius wrote on 2021-11-12, 22:18:
The only thing the end users needs to know is when the diskspace is full, and preferably, that is a situation that never should arise !
Do not ask Why !
Reply 70 of 72, by red-ray
retardware wrote on 2021-11-12, 17:26:
The DEC RM03 which is 1977 vintage was quoted as 67 MB, but are actually 64 MiB so it's a long time ago.
Reply 71 of 72, by Errius
Some old systems reckoned memory in words, but you don't see that anymore. On modern systems a word would be 8 bytes.
Another unit you rarely see nowadays is the nybble. This is 4-bits, and again is useful for programmers because it can be used to represent a single hexadecimal digit.
Reply 72 of 72, by BitWrangler
A word means the machine native bit width, so a word would be 64 bits now, and in DOS days was 16 bits. 8 bits = word was only for 8 bits.
