GD5422 BIOS weirdness
Reply 21 of 32, by slartibardfast0
ChrisXF wrote on 2022-01-13, 12:55:
Oh, I actually found 1.41 here: https://ardent-tool.com/video/1MB_Short_SVGA.html
I'll give that a go today! 😀
I too have been looking for the real bios version of 1.41 for an AST Bravo with built-in GD5422!
I tried to dump the in memory version of the TSR, thought seen as it starts with 0x55 0xAA it would work, but no luck.
time to acquire more AM27C010-200JC EPROM's for burning, cheers thanks!
Reply 22 of 32, by ChrisXF
Well, I ran that BIOS through the even/odd splitter and burnt it to an EPROM for my card... Sadly, it did NOT work: 'Eeeek, NO VGA!!' post beeps galore.
We've already more than established that my card is weird though, so maybe you'll have much better luck? Fingers crossed here! 😁
Reply 23 of 32, by weedeewee
Would you mind posting a photo of your card ?
Do not ask Why !
Reply 24 of 32, by ChrisXF
Yes, I meant to do that earlier!
Top:
1.42 MiB
Bottom:
1.26 MiB
Reply 25 of 32, by weedeewee
You said you ran the bios through the odd/even splitter. I'm assuming you mean you merged the odd/even files into one file?
I wonder what settings get saved in the XL93CS46 1024bit eeprom. 🤔
Do not ask Why !
Reply 26 of 32, by ChrisXF
Yes, that BIOS is in normal straightforward format - so I split it even and odd and copied it back /b even+odd, just as I've been doing so far with success. No dice on this BIOS for some reason though.
I've attached the file I built for reference, and the file it's originally built from.
I think that mini EPROM is for the VGA EDID or something similar. I could unsolder it and read it out if we're curious!?
    BIOS1.41 - No Luck.zip
    40.9 KiB
    11 downloads
Reply 27 of 32, by weedeewee
Looking at those files...
06h6915.bin is a normal bios you should write to an eeprom.
bios1.41.bin is fubar.
Do not ask Why !
Reply 28 of 32, by ChrisXF
weedeewee wrote on 2022-01-13, 16:30:
Yeah.... You might want to read the whole thread from the start and you'll see why that is. Writing the first .bin to an EPROM will not work at all for this card. Might work great for other cards though!
Reply 29 of 32, by weedeewee
ChrisXF wrote on 2022-01-13, 16:37:
My bad. That's annoying.
Do not ask Why !
Reply 30 of 32, by weedeewee
Are you using the same size (e)eproms ?
Do not ask Why !
Reply 31 of 32, by weedeewee
erhm...
BTW... are bios images from mca cards compatible with ISA cards ?
Do not ask Why !
