First post, by Pr0d1gy
I have the usual config file problem but cannot figure out the fix although I have searched every thread on the subject. I am on Windows XP and using the latest DOSbox.
I have seen where you need to edit the path from:
c:\poolrad\
\poolrad\save
-to-
c:\poolrad\
c:\poolrad\save\
but I can't figure out where this edit is made or how to make it.
I have tried messing with the file's properties to no avail so any help would be appreciated. Keep in mind I am a bit n00bish when it comes to editing any files or dealing with DOSbox settings (but I can find my way through the settings & my hard drive), so if you can give me some step by step it would help.
I am running everything straight off my hard drive if that helps, thanks.
