First post, by FingerSoup
								FingerSoup
								Offline
			Ok, so I've got firepower running, but I'm noticing some change in how the virtual modem works between dosbox 0.61 and 0.63...
in 0.61, the modem emulation seems to work properly, as when Firepower sends the init strings, it recieves the OK strings properly.
However in 0.63, the OK string doesn't make it to Firepower.
Any ideas? Is this a bug, a change in features, or do I need to add more settings?
