First post, by eesz34
I have a FIC PA-2005 and one of the front panel headers is a 2 pin "remote power switch". What is that for considering an AT power supply cannot turn itself off?
There's another header on it near the IDE ports:
Remote Power Supply Connector: RPW_CON
This 3-pin male connector allows you to enable (or disable) the system power
if the RPW_SW is on (or off).
I've never seen this on an AT motherboard, but I've been away from it for awhile. Google isn't of much help.
