Reply 20 of 43, by matze79
dr.zeissler wrote on 2023-01-11, 18:26:
This is how it looks like.
Oh oh, i would not place a passive Ti 200 inside.
Except you plan to drill some holes for Air Intake.
Is this nforce2 shuttle ?
i have the same machine i think.
With Mobile Athlon 1800+ (200Mhz FSB) installed (45W), HD3450 AGP Active cooled, and SSD.
I ran passive GeForce 4 MX460 and it got so hot, i had worrys.
https://www.shadowcircuit.de - german retro computer board
Reply 22 of 43, by dr.zeissler
Autsch, I bought mine without! I will take the card out and see if I can get such a fan or change it with MSI-T200 witch is passive cooled.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 23 of 43, by dr.zeissler
matze79 wrote on 2023-01-12, 22:18:
Oh oh, i would not place a passive Ti 200 inside. Except you plan to drill some holes for Air Intake. […]
yes, but mine has 3000+ Barton Core...I can't go for ATI, I have to stick to NV up to GF3 or up to FX but then there will be problems with the amithlon-cores.
Reply 24 of 43, by The Serpent Rider
Reference/MSI passive heatsink is a horrible long-term solution.
Reply 25 of 43, by iraito
dr.zeissler wrote on 2023-01-13, 06:02:
No ATI? the 9000 series would be perfect, unless this PC is meant for older than 98 stuff.
If you wanna check a blue ball playing retro PC games
Reply 27 of 43, by dr.zeissler
iraito wrote on 2023-01-13, 09:54:
yes, no ati at all. I don't want vesa or completly unaccelerated gfx in amithlon.
Reply 29 of 43, by dr.zeissler
yes, exactly "mostly" unaccelerated ati-gfx. keep in mind that even matrox-mystique! is hw-accelerated (beside the "hardware-block-move" command).
Reply 30 of 43, by Garrett W
I don't get what the issue is here. Have you encountered issues with ATi cards on this system?
In any case, the Noctua fan I was talking about is the NF-A4X10 or the NF-A4X20 if you've got some slight headroom. Make sure to grab the 5V, 3pin versions of either fan and you'll be good to go, no need to change the video card. Ziptie-ing it would actually be a good idea if you find that you can't mount it simply by screwing it in the old heatsink.
Reply 31 of 43, by dr.zeissler
Interesting! https://forum.amiga.org/index.php?topic=27916 … 24328#msg324328
GF3 with Kernel 2.04 worked excellent...
    988.98 KiB
Reply 32 of 43, by dr.zeissler
Garrett W wrote on 2023-01-14, 09:42:
Thx, I am currently hunting for the original fan or a suitable third party replacement.
Beside that I will check the "partially accelerated" ATI Cards like 7000/7500/9600.
Reply 33 of 43, by stef80
dr.zeissler wrote on 2023-01-14, 09:51:
Well, 9600 non-Pro is probably best passively cooled card in this "bracket". Sapphire had them with nice heatsinks.
Performance was somewhere between GeForce3 and GeForce4 Ti 4200.
@dr.zeissler
Low profile 60mm fan and zipties? There are plenty attachment points on this heatsink.
Reply 34 of 43, by dr.zeissler
stef80 wrote on 2023-01-14, 09:57:
Thx for the advice! I will have a look which ATI cards I have... and how well they perform.
Reply 35 of 43, by dr.zeissler
made some research...no ATI...I will go for NV or Matrox...to bad Parhelia is not supported. I own several parhelia cards and I love these P690 passive...
Reply 36 of 43, by Garrett W
Okay, so you want to turn this system into an Amiga-like using Amithlon? That was a bit confusing, why not say so from the beginning of the thread? I think you should find something that works and stick to it, in this case the GF3 Ti200 that you have in there and seems to support everything you want. All you have to do is add a fan, I do not understand your unwillingness to go with the Noctua fan, they are very quiet and push relatively decent amount of air. It's certainly a lot quieter than the fans these cards came with which were a very loud affair.
Reply 37 of 43, by dr.zeissler
I always do Multiboot, beside Amiga-Amithlon there is still
-OS2/Warp
- MsDos
- Win2k/XP
- Linux
On that same machine, so it's not about Amithlon only.
The noctura fan will not fit in that case, it can not be placed inside that heatsink.
Reply 38 of 43, by Grem Five
dr.zeissler wrote on 2023-01-14, 09:57:
I did a google search for the fan last night but found nothing. The model # on the fan only returns a number of fans with full fan housings or 3 screw hole mounts but none with the 2 screw hole mounts. These were probably made special for the manufacturer of the cards.
The version I have is an EVGA GF3 Ti200 but besides the labeling on it, it appears to be a Sparkle card with the same cooler just doesnt have the Sparkle sticker on the fan or the Sparkle labeling on the memory heatsinks.
Reply 39 of 43, by dr.zeissler
This is very helpfull! thx!!!
I am currently searching the web for such a fan...seems to be not so easy to find exact the same one.
