dgVodooo 2.8.x and related WIP versions
Reply 200 of 222, by johnnb
Dear guys, how are you I have one question if possible of course, about dgvoodoo 2
Reply 201 of 222, by Deffnator
johnnb wrote on 2026-01-23, 18:23:
Just tag dege or someone else with knowledge will answer
Reply 202 of 222, by Dege
I'm releasing the current state, with some improvements, but I'll continue testing and investigating known issues:
v2.87
  • Changes in the behavior of D3D12 feature levels
    - FL 11.0: compatibility mode with old D3D8/9 drivers (just like with D3D11)
    - FL 12.0+: most performant, zero-copy path
  • Changing some things in the D3D12 backend
    - Fixing sampler descriptors and their shader declarations that was buggy in certain cases (SM 2.x+)
    - Fixing an undervalidated sampler descriptor case for the sake of the Win11 SDK DX debug layer
    - Improving handling of read-write resource hazards for better compatibility with D3D9 drivers (Tomb Raider 2013, DX9 renderer)
    - Improving the state tracking/handling of depth/stencil planes (TR 2013, ...)
    - Fixing a bug in mapping subresources (Motocross Madness 2)
  • Improving the frontend debug layer
    - More and better readable information here and there
    - Removing old garbage reporting problems about read-write resource hazards and replacing it with an updated version
  • Fixing some minor D3D8/9 frontend bugs
  • Fixing a D3D6/7 lighting incompatibility (Tiger Woods PGA Tour 2004)
  • Adding option GeneralExt\WatermarkDisplayDuration
  • Some internal code changes
  • I finished my neglected WinMM OS uptime fixer DLL and added it to the pack
    - Not the theoretically perfect solution but at least it is a simple implementation
  • Testing dgVoodoo with
    - NV RTX 5060Ti (practically unusable with 32 bit D3D12, GPU crashes)
    - Intel Arc B580 (solid results)
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_87.zip
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_87_dbg.zip
Detection rate on VirusTotal is 3/66.
Reply 203 of 222, by lowenz
Thanks as always (since 10 years now?!)
Reply 204 of 222, by Dege
13 years. The first versions of dgvoodoo 2 were released in 2013.
Reply 206 of 222, by Deffnator
I wish Dege could also check it out the Nightmare Creatures thread at Windows
If he sorts out the stuttering issue under d3d and agp, the game is perfect
Reply 207 of 222, by robertmo3
Dege wrote on 2026-03-29, 16:57:
it is funny it supports Tomb Raider 9 released in 2013 now 😉
to add to the fun my best pc still uses i5-3450 from 2012 and runs cp2077 fine in 4k (gtx 1660) 😀
Reply 208 of 222, by Dege
I looked into the code responsible for handling fake and real fullscreen screen modes in dgVoodoo, and I did some fixes (but not many testings, I did it in a kind of rush):
  • Now fake fullscreen fully resembles the behaviour of real fullscreen.
    Except that fake fullscreen cannot handle "Centered", "Stretched" scaling modes, those are mapped to "Unspecified". But unspecified now does resolution changing when needed, as with real fullscreen.
    So, the difference between real/fake is
    - fake rendering window does not get kicked out of fullscreen state when it is obscured by other windows
    - fake fullscreen can get into "not responding" state if a game is not responding because of a long loading stage and isn't pumping the message queue
  • It might fix the annoying window-resize problem, when the fullscreen window becomes small in the corner of the screen
https://dege.fw.hu/temp/dgVoodoo2_87_fullscreen_fix.zip
Reply 209 of 222, by Dege
Expack3 wrote on 2026-03-31, 17:41:
Dege wrote on 2026-03-31, 17:39:
These Ut2004 releases are public? The last time I tried to download an 'i' or 'j' (I can't remember) version, it wasn't.
Indeed they are: https://github.com/OldUnreal/UT2004Patches/releases/latest
lowenz wrote on 2026-03-31, 20:24:
That's for Unreal '98 / Unreal Gold :D For UT 99: https://github.com/OldUnreal/UnrealTournamentPatches Ut2004 has now its own "c […]
That's for Unreal '98 / Unreal Gold 😁
Ut2004 has now its own "community patch" : https://github.com/OldUnreal/UT2004Patches (64 bit / D3D9)
Ok, thanks, I'll look into it.
Reply 210 of 222, by Dege
robertmo3 wrote on 2026-04-03, 15:53:
Tbh, it was already supported, but when doing some testing on my new hardware, it turned out that unlike my old video card, modern GPU's are more sensitive to the resource hazard coming with the D3D12 backend and I just didn't notice it earlier.
Reply 211 of 222, by Dege
I release a quick fix for 2.87 because the 64 bit D3D9 crash is embarrassing and needs to be fixed ASAP:
v2.87.1
  • Fixing the x64 D3D9 crash
  • Fixing a crash in the D3D debug layer
  • Fixing a crash with the D3D12 backend (Legend Of Grimrock 1/2)
  • Fixing a bug in the VS shader code translator (Starship Troopers)
  • Improving fake fullscreen mode to resemble real fullscreen with potential resolution changing
  • Fixing some annoying unwanted window resizing coming from dgVoodoo in fullscreen mode
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_87_1.zip
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_87_1_dbg.zip
Detection rate on VirusTotal is 1/66.
Update: I reuploaded this release with a new bugfix added on 2026.04.10.
Reply 212 of 222, by Dege
I release an incremental fix version for 2.87:
v2.87.2
  • Fixing a regression bug in DDraw DXTC colorkey-to-alpha blitting (Soul Bringer)
  • Implementing surface data prefetch in D3D9 (Sonic and All Stars Racing Transformed)
  • Improving graphics object naming for graphics debuggers (it's only for me)
  • Fixing resolving / reading back of depth-stencil textures for forced resolution / MSAA cases (D3D11/12) (Morbus Gravis)
  • Fixing a refcount incompatibility in D3D (I've Got Some Balls)
  • Fixing the calculations for old lights in D3D (I've Got Some Balls, Christmas Magic, scene demo Gothic, ...)
  • Fixing the texture mipmap generator for cube textures (Silent Hill 3)
  • Fixing an optimization bug (regression) related to DDraw textures (Grand Prix 3)
  • Fixing some internal bugs / minor leak here and there
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_87_2.zip
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_87_2_dbg.zip
Detection rate on VirusTotal is 1/67.
I want to investigate / address the fake fullscreen problem, along with other long-standing window resizing problems.
I didn't do that this time because if I make changes to the options structure then I also have to increase the version number.
Reply 213 of 222, by algeeba
Wow, you are incredible Dege. Issues with mipmap generator are fixed for Silent Hill 3. Thank you.
I don't see where I can contribute to you for the cause/coffee. Anywhere where I can donate?
Thank you again.
Reply 214 of 222, by lowenz
Dege single-handedly did the preservation of a good bunch of the gaming past of planet Earth.
Reply 215 of 222, by RetroGamer4Ever
algeeba wrote on 2026-05-16, 21:14:
Thank you again.
This is Dege's PayPal, according to his website's PayPal Donation button.
https://www.paypal.com/donate?token=RakdB5KWq … oX8V9gjWlki4fal
Reply 216 of 222, by BEEN_Nath_58
I don't know if its Windows 11 25H2 with latest updates, but dgVoodoo2 fails to load correctly for some reason is many old games. Same case with DDrawCompat. At present I am using DxWnd's ReplaceDirectXDLL feature to hook them to game, but it's weird not to have experienced it before reinstallation
Reply 217 of 222, by algeeba
RetroGamer4Ever wrote on 2026-05-17, 11:17:
Thank you RetroGamer4Ever.
The link gave me a "... this page does not exist" error but I was able to find his website and where to donate.
Reply 218 of 222, by RetroGamer4Ever
It didn't work because of the token string, but you got where you needed to go anyway.
Reply 219 of 222, by Dege
Thank you again.
Thanks, but actually it was my own bad code this time... 😀 nothing related to the game itself.
Btw, I have a Paypal donation button on the bottom of the Home section of my site. But it's not an advertise for that (I read about the new Vogons rules).
