Reply 1280 of 1558, by BEEN_Nath_58
sharangad wrote on 2024-05-04, 20:07:
BEEN_Nath_58 wrote on 2024-05-04, 19:46:
sharangad wrote on 2024-05-04, 19:43:
Ah this is on Win7. I don't have a Win7 based system to test on.
I don't think it's related to Windows. On general the OpenGL compatibility was quite same on both OS wherever I testrd
Edit: which other games had issues?
I've never been able to get front buffer writes working reliably on Win10 (all my Intel based machines are on 10).
Hexen 2 works. Will test Formula 1 now
Reply 1281 of 1558, by sharangad
BEEN_Nath_58 wrote on 2024-05-04, 20:21:
Did the loading progress bars work?
https://www.youtube.com/@sharangadayananda
Reply 1282 of 1558, by BEEN_Nath_58
sharangad wrote on 2024-05-04, 20:25:
If you mean the Loading and Client Dropdown bars, yes they work (considering you mean they move progressively)
Also Formula 1 works now
Reply 1283 of 1558, by BEEN_Nath_58
BEEN_Nath_58 wrote on 2024-05-04, 20:34:
+ Quake 2 works. I had to spend some time finding the config.cfg change of setting fullscreen to 0 (can't RReady do it itself?)
Reply 1284 of 1558, by sharangad
BEEN_Nath_58 wrote on 2024-05-04, 20:51:
There's an updated ref_v1k which can do it (it's a 1 byte change). With the alpha, If you remove Quake 2 from the games list by right clicking and then selecting "remove", delete ref_v1k manually and add the game back in a new version of ref_v1k should be downloaded which can toggle full screen (it's a bug with ref_v1k, window style ex is incompatible with modern windows). My server may be down for maintenance this week, so it might not work.
The link can also be found on this thread:
Re: RReady (Rendition Verite wrapper) Test Build (Alpha 1)
download/file.php?id=179260
[EDIT] Mind you, this is beta 3. I don't have a patched build of beta 5. In fact, I don't have a copy of beta 5. You need beta 5 for water to render correctly with v1k_nopageflip set to 1 (game internal vsync turned off).
Reply 1285 of 1558, by BEEN_Nath_58
sharangad wrote on 2024-05-04, 21:36:
There's an updated ref_v1k which can do it (it's a 1 byte change). With the alpha, If you remove Quake 2 from the games list by […]
Will test it tomorrow along with I76 (gog one should do right?), Myth TFL
Reply 1286 of 1558, by sharangad
BEEN_Nath_58 wrote on 2024-05-04, 21:38:
Yup.
Reply 1287 of 1558, by BEEN_Nath_58
Tested Interstate 76: works fine
Myth: works fine
Mech2: works fine
GPL: shows a black screen with parts of menu flickering behind
Also SC works fine: I saw I had set the game to use 1920x1080x60 which was problematic and 640x480x60 fixed it
Reply 1288 of 1558, by sharangad
BEEN_Nath_58 wrote on 2024-05-05, 13:14:
Tested Interstate 76: works fine Myth: works fine Mech2: works fine GPL: shows a black screen with parts of menu flickering behi […]
Myth: works fine
Mech2: works fine
Excellent! So i76 just doesn't work on your GTX based Win 11 system?
And a thunderstorm just started up, delaying my release.
Reply 1289 of 1558, by sharangad
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EfCDiv5h … GgJvNQ?e=Ww35z6
MD5: 61a7095867f98507a30a08b6d902c8f4
Keep dosbox in a separate folder. ICR2 should run ok now. Not tested anything else.
Reply 1290 of 1558, by sharangad
Myth: works fine
Mech2: works fine
GPL has issues with Intel HD.
Reply 1291 of 1558, by BEEN_Nath_58
Intel HD Graphics compatibility with Pentium G2020 (Ivy Bridge)
MDK: crash
Soda Off-Road Racing: crash
Grand Prix Legends: major graphical issues
Sub Culture: works
Heavy Gear: works
Die by the Sword: works
Team Apache: works
Formula 1: works
Hexen 2: works
Quake 2: works
MechWarrior 2 Titanium Edition: works
Myth The Fallen Lords: works
Monster Truck Madness 2: works
Reply 1292 of 1558, by sharangad
sharangad wrote on 2024-05-05, 13:35:
I think I know why rready crashes with dosbox randomly when using dma.
Dos box's memory access is designed for single threaded operation. The rendition support accesses dosbox ram in parallel which probably leads to corruption. I need to make it thread safe, which might make dosbox a bit slower. How slow. I don't know, but it's necessary for multithreaded operation.
Reply 1293 of 1558, by robertmo3
BEEN_Nath_58 wrote on 2024-05-05, 13:37:
Intel HD Graphics compatibility with Pentium G2020 (Ivy Bridge) […]
MDK: crash
Sub Culture: works
Heavy Gear: works
Team Apache: works
Formula 1: works
Hexen 2: works
Quake 2: works
you missed Monster Truck Madness 2 😉
Reply 1294 of 1558, by robertmo3
sharangad wrote on 2024-05-04, 11:10:
- vQuake is showing signs of life, but it doesn't run. It no longer produces BIOS errors and appears to be running
it is not running
you can type "cls" and hit enter in dosbox window 😉
Reply 1296 of 1558, by sharangad
robertmo3 wrote on 2024-05-05, 14:58:
nascar2 and rebel moon are very slow now
Will check.
Reply 1297 of 1558, by sharangad
If you fire up RLauncher and hit view log do you have a lot of stuff in there?
