Reply 200 of 1558, by sharangad
https://1drv.ms/u/s!As-dKk-N73dSllhtj9OqZsFHfQ9Q?e=suzg7x
MD5: 2a653f87efe287fe807a76827161d47a
This should produce one or more crash dump logs (with extension .dmp). If you could share the dump files after reproducing the crash it would help. At the moment I'm flying blind because there's no indication of a crash.
https://www.youtube.com/@sharangadayananda
Reply 201 of 1558, by RaVeN-05
tested ncube & nfinal , yes they are different
https://www.youtube.com/watch?v=di7fiq8ElxA&a … WhiteMagicRaven
particulary here
https://youtu.be/6p4-39uwZbs?si=wDZEcVXj-gAoZEJz&t=93
https://youtu.be/di7fiq8ElxA?si=Xgb-yu89AvcDUuGC&t=308
and
https://youtu.be/lFGuGm5UEj8?si=pcdcwhvaq5cTsKna&t=82
https://youtu.be/di7fiq8ElxA?si=CVp73VVWYCWzF7Lp&t=83
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 202 of 1558, by RaVeN-05
Spoiler
Problem signature:
Problem Event Name: APPCRASH
Application Name: VH2.exe
Application Version: 0.0.0.0
Application Timestamp: 346a08f1
Fault Module Name: redline.dll
Fault Module Version: 1.0.1.47
Fault Module Timestamp: 653bcb31
Exception Code: c00000fd
Exception Offset: 00004495
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: cfe3
Additional Information 2: cfe37e674d3deb9e77ad28f5ee0233ca
Additional Information 3: bb88
Additional Information 4: bb88537c801ea5df8225d8a738380be5
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
    Hexen II.7z
    71.49 KiB
    36 downloads
    dumps
    RReadyLog.zip
    227.1 KiB
    37 downloads
    logs
Reply 203 of 1558, by sharangad
RaVeN-05 wrote on 2023-10-27, 15:35:
tested ncube & nfinal , yes they are different https://www.youtube.com/watch?v=di7fiq8ElxA&a … WhiteMagicRaven […]
particulary here
and
Thanks dude.
Reply 204 of 1558, by sharangad
Try this:
https://1drv.ms/u/s!As-dKk-N73dSllkW9VipxVHi0OzT?e=a0h2Qv
MD5: 594c504ff1b01e17b04e988a1a79da12
RReady appears to be running out of RAM or suffering from fragmentation. I've increase the custom heap for RRedline API memory allocation to 256 MB from 128 MB for vHexen II (and nothing else). RReady has a much higher memory footprint than an acutal Verité board unfortunately.
If it crashes it should be somewhere else. I didn't increase the heap size for everything because some apps don't like it very much. If I do increate it everywhere, I'll have to test it to death.
A custom heap allows me to allocate memory like in Win98. But the problem is it's smaller than available RAM. Hexen 2 will not run on modern systems without a custom heap, either that or with Win98 compatibility which doesn't work on a lot of systems anymore (audio driver crash).
Reply 205 of 1558, by sharangad
particulary here
and
I don't get the underlining under ncubed either. Could it be we have different versions of the same binary?
Reply 206 of 1558, by RaVeN-05
Good News ) HeXen II no crashes anymore.
"I don't get the underlining under ncubed either" ignore it this is glitch appeared once. The differences in cube itself, on original hardware here is too many quadratic outlines while in rready emptiness here.
videos by time code
HeXen II visual anomalies remains to be fixed : in video running on hardware and than on rready
https://www.youtube.com/watch?v=CmhjDUMwOFM
in case you need those testing demos , put in data1 folder and in console playdemo rr1 etc, i guess you already know all that )
    data1.7z
    710.5 KiB
    37 downloads
    hexen 2 testing demos
Reply 207 of 1558, by sharangad
RaVeN-05 wrote on 2023-10-28, 08:51:
Good News ) HeXen II no crashes anymore. […]
videos by time code
Thanks dude. It's good that it doesn't crash anymore. Hexen II bugs it is then. The demos will be very useful.
Reply 208 of 1558, by RaVeN-05
also you right AA currently better on original hardware =(
https://youtu.be/On8D8cqqwoo
i also created couple of screenshots directly writted by games Quake, Quake2 , Hexen II (vh2 unfortunatelly buggy at screenshots)
they all antialiased, and some comparison shots of same exact scene with and without AA. in game message "NO!" means AA turned off.
in closer , it looks like some kind of post processing , where accurate per-pixel gradients appear based on nearest neighborhoods ? and it uses some factor to blend by data from "how close pixel should be?" hard to explain. Only guess , seems proprietary AA and its miracle it works very fast, unbelievable speed for 1997, but not looks like what other AA techniques does .
Thank you very much! =)
    screenshots.7z
    1.32 MiB
    34 downloads
    vQuake II + vHeXen II shots
    Quake.7z
    4.56 MiB
    36 downloads
    vQuake shots
Reply 209 of 1558, by sharangad
I never fully deciphered the RRedline Quake specific AA call. Only the two pairs of coordinates, which describe a line and some sort of blending factor. There were other values there. I even started really hard at Rendition's Quake specific AA patent, but couldn't correlate the AA data to that other than the fact that lines were being drawn.
I shall put the effort in. Moving on to vQuake 1 there's one more undocumented Quake specific call VL_QLIGHT. Quake 2/Hexen 2 don't appear to use this. Maybe Hexen 2 does and I'm missing it. VL_QSpan, used for world/background rendering took me 3 months to figure out. In the end it turned out to be something ridiculously simple. Not completely simple, but too simple for the sort things I was trying.
How would Vogons like me to fix the issues? AA first, hexen 2 second?
I have no idea how long fixing these things will take. But I'm in for the long haul.
I think I'll go with the antialiasing. Underwater scenes in vh2 look horrible without AA.
Reply 210 of 1558, by RaVeN-05
oh my god . hard really hard work.
i remember IndyCar Racing II can turn on /off antialiasing by alt+a while in game.
some sdk and race to redline also do AA
Q1,Q2,H2 too we all know.
Feel free to ask me.
What i need to try to do? Test something?
P.S. Edit
AA + low resolution = outstanding effect , which actually defect , in some way it weird , in another its beautiful, happens on both v2100 and v2200, can someone confirm how it looks on v1000?
https://youtu.be/krY2t9Xz1Jw
Reply 211 of 1558, by sharangad
RaVeN-05 wrote on 2023-10-28, 11:13:
oh my god . hard really hard work. […]
No tests for the moment. A lot of the hexen II texture corruption I've figured out. The RRedline demos do AA correctly. They draw AA lines. There's a regular documented call which is correctly implemented. ncubed and nfinal use them to draw coloured lines around the edges of the spinnig cubes. I just redirect them to the appropriate OpenGL call both for lines and edges.
Quake engine games use a proprietary call called:
V_FIFO_QAAZEDGE ( at least that's the id in the command buffer). I don't know if there's an API call for it. The data just gets added to the command buffer. I read and partially interpret the data. I know they're lines and I know where the lines begin and end. The rest is mostly a mystery. I'll fix that once I fix the texture corruption issues.
The texture corruption issues are caused by a format conversion. Quake 2's blood particles are a solid texture which ends up being reinterpreted as an alpha texture (which looks like a circle made up of 1s and the transparent backround of 0s). This is multiplied by a colour to convert the alpha (1,1,1, a) to (r, g, b, a) making circles of different colours. WIthout particle aa, Quake 2 (and hexen 2) use an RRedline call to draw square particles.
The issue with the textures is it's converting to a format I've never tested the conversion before for. On actual hardware it's just a format register. Change that and the card reinterpretes the texture data while processing. With RReady, there's an uploaded RGBA texture. This needs to be converted to a format that's never been tested before.
No testing for now. I need to fix the bugs. It'll probably be a few days before you I post here again.
[EDIT] Oh and the dragon appears to be missing polygons. The texture over there doesn't have transparency so that's my best guess at the moment.
Reply 212 of 1558, by filipetolhuizen
I have to say this seems promising, but sadly I have no Rendition cards to test it. Nevertheless, I would like to ask if a Rendition wrapper for those who have other cards could be expected?
Reply 213 of 1558, by BEEN_Nath_58
filipetolhuizen wrote on 2023-10-28, 16:28:
What do you mean by "other cards"?
Reply 214 of 1558, by filipetolhuizen
BEEN_Nath_58 wrote on 2023-10-28, 16:33:
Others than Rendition (I believe only nVidia and AMD are our choices for the daily PC, now).
Reply 215 of 1558, by sharangad
filipetolhuizen wrote on 2023-10-28, 17:39:
RReady listed on the first page will run Rendition apps on nvidia and amd gpus., though at the moment only Windows Rendition apps.
Reply 216 of 1558, by BEEN_Nath_58
nVidia, AMD and Intel. It is already out and is getting updated to fix bugs.
Reply 217 of 1558, by sharangad
Here's something to test (vHexen II fix, not fully tested):
https://1drv.ms/u/s!As-dKk-N73dSllpTCzMQ_VX5T9Ju?e=a15SJ0
MD5: cf0c83d786f04f0e957c35c5c9c72eb9
The multicoloured textures should be working properly now in glorious RGBA4444.
This was caused by a render to texture issue. Render to texture as used by RReady is RGBA32, so the pixel format for binary reinterpretation of texel data didn't work because reading back a 32 bit RGBA value as an RGBA444 pel didn't produce the exact result. Render to texture only supports a limited number of formats. I didn't bother testing which ones worked. Instead I added a whole other CPU based codepath to render to virtual rendition VRAM directly as well as the usual render to texture (which would work if used directly without translation). This only affects VL_Lookup, a function used by the Quakes/Hexen II. v1k_surfacelookup exclusively uses this function. Quake 2 didn't need this at all, but I enabled it for everything that needs VL_Lookup, just in case. Now VL_Lookup is even slower.
The textures should work correctly now though and a round of optimisation later on wil be needed.
[EDIT] The dragon/demon appears to be a chroma keying issue. The colour black is being set to be filtered out so the missing polygons are coloured black in demos rr1 and rr3. That shouldn't be set. I have no idea why I'm getting this sequence, but it doesn't look like a mistake on the part of the game or a bug in RReady. And RReady is rendering it correctly. But the on actual hardware it renders correctly, so what's going on here?
Reply 218 of 1558, by RaVeN-05
Tested, cool, those palette corrupted textures fixed, even bronze golem now have green laser, still not become green fully, but i see it changes palette and become little brighter, with one corrupted color (gray) so i guess its some kind of share palette extension might be here or related, like OpenGL legacy had GL_EXT_paletted_texture and GL_EXT_shared_texture_palette. ( https://www.vogonswiki.com/index.php/List_of_ … texture_support )
"so what's going on here?" i can only guess , i once saw somewhere not even remember where, one game had 256 (8-bit) palette with two black colors at various indexes (those two match each other 0,0,0 = 0,0,0)
one black color used as transparency other as just black color, maybe here same case?
ok now, demos rr1 and rr3 only actual , showing transparency and particles , particles already work great in Quake2 so maybe you can backport to vh2, vh2 particles sometimes discard part of particle being drawn under, like alpha blending objects discard to draw something behind them. When you die in lava camera stuck , while on original HW you will drown , move to ground.
tested Quake2 in curiosity how in lava death looks like here, and it crashes game, in console "map q2dm3". (will check in real HW if its same goes here)
played around with AA , i set all antialiasing to max in nVidia control panel for quake2.exe and for vh2.exe and it works for actual resolution (800x600 in game) without any enforcements by rready launcher.
this AA applies on world and models.
if i enforce resolution to higher, AA still works for models, but not for world.
this AA have no effect underwater , no matter of resolution .
i wanted to apply some AA shader based techniques , the ReShade can do postprocessing, but after installation reshade into any rendition verite game it corrupt everything, except 2d elements on screen, huds, game menu etc. Except vh2.exe, here it works.
Thinking of AA, implementing AA like on real hardware valuable for underwater and world, how it will act on scaling while resolution enforcement will be set in rready's launcher i can't imagine.
Currently world scaled as point sampled, if its possible to set linear filtering for scaling world would be little better, it will make very little blur and prevent to spot that game actually a low resolution game.
for particles already everything excellent here (except vh2 case).
for models i think using modern AA provided by video card is best option as modern AA is more advanced than way back on original hw. (only rendition AA approach is useful while underwater.)
applying AA data sent by app for models (while resolution enforcement used) guess is bad idea , because data meant to be for resolution that used in game and not on rlauncher , the models have more advanced geometry on higher resolution and renditions AA data at low resolution, they will not match for each other , not valid information about edges from app, i guess.
Maybe its possible to guess how renditions AA works by making screenshot on real hardware v1k_drawflat 1 with AA and Without. Photoshop can use difference in layer blending. By same exact place in rready maybe possible intercept AA data (data about edges) and having all that start guessing how it all works.
AA at low res on real hw can produce funny artifacts shown here https://youtu.be/krY2t9Xz1Jw
Reply 219 of 1558, by sharangad
Everything except Green Gola fixed (untested against other apps, use at your peril):
https://1drv.ms/u/s!As-dKk-N73dSllsqNqDe_IwSScoi?e=OIMXCj
MD5: a935cd0618ab4b85381850453ba4cb74
You're right, the water particles were caused by z-buffering. I added a special case for vh2 (by disabling depth writes. The particles are the last things drawn and they're transparent, so not updating z won't be a problem (hopefully). Depth testing is still there so they won't show through walls).
That'll be the last build of the day. Tomorrow, the green golem and hopfully will move onto deciphering the special Quake AA. I didn't put much time in, because I had a lot more to do. Windows is mostly done, barring bugs so I can get back to AA. It won't be impossible to decipher it, it'll just take some time.
