Reply 40 of 102, by rmay635703
- l33t
Get an nes or gameboy Emulator running on a 286 then call me 😉
I am curious though besides one gameboy emulator and a z80 cpm emulator were there any emulators for 286 machines?
c64 emulator on pc/xt hercules 😀 (true!)
neoragex was as fast as a neogeo which I used to run on a K6-233, ran every ROM I had too. Genecyst and zsnes (already mentioned) worked fine on that machine too (and I suspect they would work on lesser hardware just fine). Earlier versions of mame running classic non 3D arcade games upto say early 90's (such as NBA jam, Commando, iRobot, start wars etc) worked fine. tbh I never found speed a problem, it was more compatibility. I had various other MegaDrive and 32X emulators such as AGES and when they worked, were very playable, but at the time didn't support a lot of titles. Emulation for those systems was in it's infancy then. an N64 emulator I has (can't remember the name) struggled though.
On a P3/800 I used to run PSEemu and ePSXe which both played ISO's faster and higher resolution than a PlayStation ever could. I used to play Tony Hawks, Wip3out and various 3D beat-em-ups (EvilZone, Dead or Alive, Tekken) at 800x600 (PlayStation maxed out at 640×480) with ATi Rage Pro. Smooth as silk. I suspect lesser hardware would work too since the GFX was doing most of the work in these situations (say P3/500 etc). I was using WinUAE on the P3/800 at that time, which worked as fast as the Amiga500plus I used to have, can't remember emulating various other accelerators though, and probably not going beyond the Amiga CPU timings.
neoragex? what version?
what about the others (c64/atari-st/amiga/nes/snes/etc.)
I am actually collecting Emulators for my P200MMX.
It depends, if the emulator uses SSE2 the atom could be better.
Generally I think Atom IPC ~= P4 IPC.
My 200MMX has no SSE. Actually I am preferring Emulators that run in Dos over the early pendants in windows on my Win95b setup. It seems that the Emulators for Dos are faster and better, even if they are started from the Win95-Desktop.
The early Css64-Version runs really good and does not produce sound stuttering or flickering image.
I was messing around with the last DOS version (0.70??) of MEKA the other day on my 233MMX. It goes pretty well; seems to run most Master System / Game Gear games at full framerate and I didn't notice any emulation issues. Might be worth a try.
Thx, what Games should I try (are best) on that machines?
I checked "fellow" for Dos. This is so much better than "UAE"! on my P200MMX.
Though it does not use a 50HZ Resolution on my TFT, but 640x480 with 60Hz is just fine. Centered Image, Sound is good, animation is good.
wrote:neoragex? what version?
0.6b and 0.8c were the ones I used. I also used something called the "redblood bios", which as the name implies made metal slug 'blood' red instead of usual grey/light blue colour. 😉
wrote:what about the others (c64/atari-st/amiga/nes/snes/etc.)
As mentioned, zsnes had no problems with any of the roms I had iirc. Amiga was always WinUAE (but on a P3, bit later). I don't think UAE was that great at the time.
For Megadrive/Genesis (if you are interested), Genecyst was the best by far, but also AGES, Megasis and KGEN98 worked on my K6-233.
wrote:Get an nes or gameboy Emulator running on a 286 then call me 😉
I expect so, given that I used a PC emulator (PCTask) on an Amiga eons ago (before I even got a PC) to emulate DOS... which worked, albeit in a limited capacity, I suspect there were emulators on PC systems then too.
wrote:neoragex was as fast as a neogeo which I used to run on a K6-233, ran every ROM I had too. Genecyst and zsnes (already mentioned) worked fine on that machine too (and I suspect they would work on lesser hardware just fine). Earlier versions of mame running classic non 3D arcade games upto say early 90's (such as NBA jam, Commando, iRobot, start wars etc) worked fine. tbh I never found speed a problem, it was more compatibility. I had various other MegaDrive and 32X emulators such as AGES and when they worked, were very playable, transfers CDGbut at the time didn't support a lot of titles. Emulation for those systems was in it's infancy then. an N64 emulator I has (can't remember the name) struggled though.
Thank you very much for this information
Don't know if it will run on a 286 but it certainly will under Dos. http://zboy.sourceforge.net/
I love it, when they still code something new and useful for DOS. 😘
Still plenty of embedded systems running on Dos.
Gens, the old Sega megadrive emulator is fantastic it runs even on windows 95 + pentium 100 or 150 at full speed
today is the 2nd best megadrive emulator behind Fusion yet it run perfect in win 10
spiroyster wrote on 2019-07-27, 22:01:wrote:neoragex? what version?
So at rom launch when you see the unibios screen, push A+B+C together. In region chose Japan; I guess this should be uncensored with red blood
dr.zeissler wrote on 2020-01-29, 06:38:spiroyster wrote on 2019-07-27, 22:01:wrote:neoragex? what version?
I don't remember doing any of that tbh, I think unibios is something different? this was 20+ years ago though 😉. iirc it was a just a bios file that you put into the bios folder and ran neoragex, made the SNK logo red and had the red blood on metal slug. Don't think it worked with any other ROM (or at least I don't remember trying). I've probably still got it somewhere in my archives, will post it if I find it.
Gens was never fast in my experience... I preferred Steve Snake's emulators to Gens for the performance, accuracy, and not forcing my desktop to 16bpp when it runs.
Debian's fucked
rmay635703 wrote on 2019-06-29, 15:42:Get an nes or gameboy Emulator running on a 286 then call me 😉
NO$GMB? I'm sure I've seen someone running it on an HP200LX.
there is even a c64 emulator for a XT/Hercules 😀
