Fastest emulators period
Emulation of old consoles and arcades.
Re: Fastest emulators period
Postby rmay635703 » 2019-6-29 @ 15:42
Get an nes or gameboy Emulator running on a 286 then call me ;)
I am curious though besides one gameboy emulator and a z80 cpm emulator were there any emulators for 286 machines?
User avatar
rmay635703
Postby dr.zeissler » 2019-6-29 @ 16:54
c64 emulator on pc/xt hercules :) (true!)
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby spiroyster » 2019-6-29 @ 17:40
neoragex was as fast as a neogeo which I used to run on a K6-233, ran every ROM I had too. Genecyst and zsnes (already mentioned) worked fine on that machine too (and I suspect they would work on lesser hardware just fine). Earlier versions of mame running classic non 3D arcade games upto say early 90's (such as NBA jam, Commando, iRobot, start wars etc) worked fine. tbh I never found speed a problem, it was more compatibility. I had various other MegaDrive and 32X emulators such as AGES and when they worked, were very playable, but at the time didn't support a lot of titles. Emulation for those systems was in it's infancy then. an N64 emulator I has (can't remember the name) struggled though.
On a P3/800 I used to run PSEemu and ePSXe which both played ISO's faster and higher resolution than a PlayStation ever could. I used to play Tony Hawks, Wip3out and various 3D beat-em-ups (EvilZone, Dead or Alive, Tekken) at 800x600 (PlayStation maxed out at 640×480) with ATi Rage Pro. Smooth as silk. I suspect lesser hardware would work too since the GFX was doing most of the work in these situations (say P3/500 etc). I was using WinUAE on the P3/800 at that time, which worked as fast as the Amiga500plus I used to have, can't remember emulating various other accelerators though, and probably not going beyond the Amiga CPU timings.
User avatar
spiroyster
Postby dr.zeissler » 2019-7-07 @ 21:23
neoragex? what version?
what about the others (c64/atari-st/amiga/nes/snes/etc.)
I am actually collecting Emulators for my P200MMX.
dr.zeissler
Postby happycube » 2019-7-08 @ 04:48
It depends, if the emulator uses SSE2 the atom could be better.
Generally I think Atom IPC ~= P4 IPC.
happycube
Postby dr.zeissler » 2019-7-08 @ 04:55
My 200MMX has no SSE. Actually I am preferring Emulators that run in Dos over the early pendants in windows on my Win95b setup. It seems that the Emulators for Dos are faster and better, even if they are started from the Win95-Desktop.
The early Css64-Version runs really good and does not produce sound stuttering or flickering image.
dr.zeissler
Postby xjas » 2019-7-08 @ 05:13
I was messing around with the last DOS version (0.70??) of MEKA the other day on my 233MMX. It goes pretty well; seems to run most Master System / Game Gear games at full framerate and I didn't notice any emulation issues. Might be worth a try.
User avatar
xjas
Postby dr.zeissler » 2019-7-08 @ 10:43
Thx, what Games should I try (are best) on that machines?
dr.zeissler
Postby dr.zeissler » 2019-7-08 @ 19:12
I checked "fellow" for Dos. This is so much better than "UAE"! on my P200MMX.
Though it does not use a 50HZ Resolution on my TFT, but 640x480 with 60Hz is just fine. Centered Image, Sound is good, animation is good.
dr.zeissler
Postby spiroyster » 2019-7-27 @ 22:01
dr.zeissler wrote:neoragex? what version?
0.6b and 0.8c were the ones I used. I also used something called the "redblood bios", which as the name implies made metal slug 'blood' red instead of usual grey/light blue colour. ;)
dr.zeissler wrote:what about the others (c64/atari-st/amiga/nes/snes/etc.)
As mentioned, zsnes had no problems with any of the roms I had iirc. Amiga was always WinUAE (but on a P3, bit later). I don't think UAE was that great at the time.
For Megadrive/Genesis (if you are interested), Genecyst was the best by far, but also AGES, Megasis and KGEN98 worked on my K6-233.
rmay635703 wrote:Get an nes or gameboy Emulator running on a 286 then call me ;)
I expect so, given that I used a PC emulator (PCTask) on an Amiga eons ago (before I even got a PC) to emulate DOS... which worked, albeit in a limited capacity, I suspect there were emulators on PC systems then too.
User avatar
spiroyster
Previous
Return to Console & Arcade Emulation
Who is online
Users browsing this forum: No registered users and 0 guests
