Reply 40 of 40, by Sombrero
DosFreak wrote on 2022-08-01, 17:05:
For Portal 2 (Build v7293 was last build I tested) on Vista and above I use the command "portal2.exe -steam", also drop the .dll in the bin folder.
As far as Goldberg version it shouldn't matter. I want to say Vista compatibility is broken but 7 should still be fine and I haven't yet had to revert to an older version of Goldberg to get a game to work (except for Vista).
If the above doesn't work let me know and I'll do another test.
Awesome, works perfectly! Thanks! Now I can play every game I have on steam without it, I won't be bothered by loss of OS support or anything else like that going forward.
Or had on steam, the account is gone. Only thing I had left was a Windows 7 install with Steam on offline mode and a few games installed you still can't get anywhere else than from Steam.
DOS/Win98SE: Pentium III 650MHz / Voodoo 3 3000 / Sound Blaster Audigy 2 / Orpheus
WinXP: Pentium 4 HT 651 3.4GHz (65W) / 9800 GTX+ / Sound Blaster X-Fi
Win7/10: Xeon E3-1230 v3 / GTX 1660 Ti / Sound Blaster Z
