Reply 21 of 36, by alienmannequin
Recently installed Carmageddon 2: Carpocalypse Now on '98. It stated that QT was required "for optimal performance" or similar, and to install it. Chose not to install, game seemed to run just fine. What's missing?
Reply 22 of 36, by HandOfFate
Maybe it's needed for the intro movie. Did you see it?
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 23 of 36, by AlaricD
skitters wrote on 2020-06-08, 19:03:
Here's my list. It's not complete.
Connections
Came here to say Connections but you beat me to it (by some months, even). Loved the TV show. I still need to finish that game.
Reply 24 of 36, by alienmannequin
HandOfFate wrote on 2020-08-12, 09:23:
Good question - can't remember now. I'll load it up again soon and check, but that would make sense.
Interesting how it was semi-negotiable, in that you could play the game without installing a major component. Imagine that happening these days...
Reply 25 of 36, by utahraptor
On the topic of the original Myst, there was a making of video on the CD that was very interesting and gives some insight into just how small a crew they were and how they were able to do great things without a lot of resources. There is a copy on YouTube: https://youtu.be/CGN2W7o1N2s
Reply 26 of 36, by HandOfFate
That was an interesting watch, thanks for sharing 😀
I would never have guessed that the game was using 8-bit paletted images. I should try playing it again, and see if I can actually solve a single puzzle this time around 😜
Reply 27 of 36, by 1ST1
I can add two more:
Under Windows 3.11 (not compatible to Windows 95 and newer):
- XPLORA1: Peter Gabriel's Secret World
Under Windows 95 (not compatible to Windows 3.11 and earlyer)
- Peter Gabriel's EVE
So a big big big Peter Gabriel fan (like me) needs Windows 3.11 and 95. I have both games here in original boxes.
Reply 28 of 36, by notsofossil
The Nikolai education games require QuickTime for their Windows versions. That includes the following:
Nikolai's Trains
Toys
Knights
Pharaohs
Mysteries
Pirates
Treats
In Outer Space
Thinkpad T42 Win9x Drivers | Latitude D600 Win9x Drivers
Next: Dell Inspiron 8000
Reply 29 of 36, by dormcat
946.92 KiB
As you can see, a QuickTime logo is clearly visible on the CD-ROM. IMHO it was used only for the opening animation, though.
Reply 31 of 36, by Jo22
Rawwwrrrr.. 😁
Reply 35 of 36, by CDrayan
The Blaster games that had FMV cutscenes (Mega Math Blaster, Math Blaster Ages 9-12, etc.) always used QuickTime for their Mac versions. The Windows versions used Video for Windows instead at first, using the same AVI files for both platforms. The 1999 "For 3rd Grade" release of Mega Math Blaster not only fixed the Y2K bug, but also moved to QuickTime 3 for the Windows version. Post-2000 releases of Ages 9-12 moved to QuickTime 5.
If a game uses QuickTime 2.1, newer QuickTime versions will not work with it. However, games that use QuickTime 3 or higher will happily run with newer versions. This is as far as Windows is concerned; I didn't find any such issue with Mac OS 9.
Reply 36 of 36, by Retrograde_i486
Sorry to bump an old thread but I Just installed the 2004 release of Bad Mojo and it came with Quicktime 6.5. May try installing a newer version as I'm not getting any sound on the videos in game or out but they do play.
