beneath a steel sky and touche
First post, by bushwakko
i've gotten a hold of both games, talkie version of BASS.
beneath a steel sky exits with this error before it even starts:
INTERRUPT 0DH, GENERAL PROTECTION FAULT possible illegal address
error code = 0000
eax = 0000000C esi = 00000000 flags = 3206 ds = 01BF
ebx = 00000001 edi = 0005CE60 eip = 0000BD2A es = 01BF
ecx = 00000000 ebp = 00000004 cs = 01B7 fs = 0187
edx = 0005FE00 esp = 0005FDE4 ss = 01AF gs = 017F
Press any key to continue . . .
and touche just exits... any comments?
Reply 2 of 30, by bushwakko
ok, why doesn't it?
what's this doxbox thingy then?
Reply 3 of 30, by Zorbid
Dunno why it doesn't work in XP, but AFAIK it won't work in DOSBox (protected mode).
DOSBox is a x86+DOS emulator.
http://dosbox.zophar.net for more info.
Reply 4 of 30, by Harekiet
Rank DOSBox Author
DOSBox Author
Might wanna try the cd32 amiga version, should be downloadable from a certain site on the net. That runs fine here.
Reply 5 of 30, by Nicht Sehr Gut
From Microsoft's knowledge articles:Beneath a Steel Sky uses a memory model not compatible with Windows 95. Run it in MS-DOS mode., which suggests that it is using some unusual memory "tricks" to work.
Do a quick search of the board with "Beneath a Steel Sky", especially:
showthread.php?s=&threadid=186
"Back to the Roots" has a freely downloadable 32-Color CD32 version than runs well in WinUAE.
http://www.back2roots.org/
There's a better 256-color version that is basically identical to the PC version, but it's neither freely downloadable nor easy to find (very rare apparently).
Reply 6 of 30, by Stiletto
Read this thread for ideas on Touche:
showthread.php?s=&threadid=427
do the Fandango!" - Queen
Stiletto
Reply 8 of 30, by Nicht Sehr Gut
On "Touche", I presume you're referring to "Touche': The Adventures of the Fifth Musketeer".
Two things to check.
1) Does it do the same thing without VDMSound (may need to reconfigure the game to test this)?
2) Is it installed on the C: drive in a directory named "TOUCHE",
C:\TOUCHE
I believe that this may be one of those games that demands that you place it in the root of your C: drive for it to work.
Reply 9 of 30, by bushwakko
wouldn't it be kinda nice to get the bass cd version working under xp then, it did work under 2k rite? some of you guys should be able to fiddle a little with it 😉
i refuse to hear that something which works under 2k won't work under xp, that's lame!
Reply 10 of 30, by Nicht Sehr Gut
Originally posted by bushwakko what's this doxbox thingy then?
BTW, you can disregard using "Touche" on DosBox as well. It uses DOS4GW (protected mode game).
Reply 11 of 30, by Stiletto
According to DOSFreak's compatibility list, Tribes also works in 2000 and not in XP. But yes, sometimes it happens, and we don't always know why.
Stiletto
Reply 12 of 30, by Snover
Hey... we should lobby the guys that made BASS and see if we can fenagle a 256-colour CD32 version from them. I wonder if they even have copies anymore...hmm...
Yes, it’s my fault.
Reply 13 of 30, by bushwakko
well, but wasn't the problem that it didn't work on xp, but it worked on 2000? why is that? it seems only logical that there should be a way to get it to work on xp?
Reply 14 of 30, by Snover
Try using a Windows 2000 compatibility mode?? *eg*
Yes, it’s my fault.
Reply 15 of 30, by DosFreak
I'm think with Tribes that it's gotta be a video driver problem....anyways you can use OpenGlide with Tribes (although last time I check there were graphical anomalies) so that should solve the problem.
Make your games work offline
Reply 16 of 30, by Snover
That's one way to solve the problem, uh, heh...
*no comment*
Yes, it’s my fault.
Reply 17 of 30, by bushwakko
what's the difference from 2k to xp that could make such a basic dos game work with one but not the other?
Reply 19 of 30, by bushwakko
and no way to get it to work on both?
