First post, by Guest
Are there any plans to port VDMSound to linux? Or is it even possible?
Hmmm?
yes? is there going to be a linux version?
And what should that linux version do then?
There is already dosemu for Linux.
V.
wrote:Or is it even possible?
Sorry, but it is not. VDMSound is not a DOS emulator, it just provide virtual devices to the standard Windows NTVDM, so a DOS program believes it's running in a machine with a SoundBlaster card and a few more things. Since it's not a full emulator or a full VDM, it cannnot be ported to Linux.
If you want to run old DOS programs inside Linux you need dosemu or DOSBox.
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
Wasn't sure excactly what VDMSound did, that's why I asked. thanks for the info 😀
too bad dosbox is REALLY slow in linux. should be possible to make a dos-wrapper in linux too though, without having to emulate everything. 😀
anyone know of such a project?
Dosemu is not the same as dosbox. 😉
V.
dosbox is quite easy to set up. dosemu is a bitch.
It may be a bitch, but it's the answer to your "anyone know of such a project" question. (sic!)
V.
