First post, by jjjadef
After reboot logo is reappeared
after 2 relocations it says "You have used your allocation of unlock codes".
What to do.
Thanks
What to do.
Thanks
Is that v1.43 of Glidos?
Yes 1.43
yes 1.43 (c) the last in french and VISTA but before reboot or shutdown that play perfectly.
the logo reappeared after reboot or shutdown.
Thanks
Thank you, very much.
But i do not understand English and i thought it needed to install an older
version to avoid having the logo after each shutdown.
But it does not play, I think because that older version it is not
compatible with Vista.
No. You must use the latest version, and if the logo reappears after reboot, then please run MIBTest and post the results.
Thank you very much.
It works perfectly for now.
I am afraid, however, lose the pick release.
But I test this having long played Tomb Raider 1.
I understand we do not reinstall it if Glidos again. Just reactivate with
the same code. I think my error came from there, because I thought the
release was the PC and not the program.
Thank you very much and congratulations for this wonderful program !
TRADUCTION GOOGLE de:
Merci beaucoup.
ça marche parfaitement pour l'instant.
J'ai peur cependant de redémarrer pour perdre le déblocage.
Mais je testerai celà après avoir longtemps joué à Tomb raider 1.
Si je comprends bien il ne faut surtout pas réinstaller Glidos si ça
recommence. Juste réactiver avec le même code. Je pense que mon erreur
venait de là, car je croyais que le déblocage concernait le PC et non le
programme.
Merci encore beaucoup et bravo pour ce merveilleux programme !
It worked very well, after shutdown of PC new id has changed unfortunately.
Before: GlidosID: 81BB27CBB673A10C2045978ADCDC038B
After: GlidosID: 8E90C756FDC721E5008DC54C6D7ABA7C
I do not dare turn off my PC!
What to do ?
Thanks
TRADUCTION GOOGLE DE:
Oui Alors que ça marchait très bien, après extinction du PC l'id a à
noiuveau changé hélas.
Avant : GlidosID: 81BB27CBB673A10C2045978ADCDC038B
Après : GlidosID: 8E90C756FDC721E5008DC54C6D7ABA7C
Je n'ose plus éteindre mon PC !
Que faire ?
Merci
[0,24] (Software Loopback Interface 1)
[1,131] (Miniport réseau étendu WAN (L2TP))
[2,131] 50-50-54-50-30-30 (Miniport réseau étendu WAN (PPTP))
[3,23] 33-50-6F-45-30-30 (Miniport WAN (PPPOE))
[4,6] 88-50-20-52-41-53 (Miniport réseau étendu WAN (IPv6))
[5,6] 88-50-20-52-41-53 (Miniport WAN (IP))
[6,23] 20-41-53-59-4E-FF (Carte asynchrone RAS)
[7,131] (WAN Miniport (SSTP))
[8,6] 86-F7-20-52-41-53 (Miniport réseau étendu (Moniteur réseau))
[9,6] 00-1E-EC-FD-D9-ED (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.0))
[10,71] 00-21-00-94-70-7C (Réseau local Broadcom 802.11b/g)
[11,131] 02-00-54-55-4E-01 (Teredo Tunneling Pseudo-Interface)
[12,6] 80-00-60-0F-E8-00 (Microsoft Windows Mobile Remote Adapter)
[13,6] 80-00-60-0F-E8-00 (Microsoft Windows Mobile Remote Adapter #2)
[14,131] 00-00-00-00-00-00-00-E0 (6TO4 Adapter)
[15,23] 00-FF-00-30-00-00 (ECI Telecom USB ADSL WAN Modem)
[16,131] 00-00-00-00-00-00-00-E0 (isatap.{651AF039-0681-4784-B265-4E54DD6184D5})
[17,6] 88-50-20-52-41-53 (Miniport réseau étendu WAN (IPv6)-QoS Packet Scheduler-0000)
[18,6] 88-50-20-52-41-53 (Miniport WAN (IP)-QoS Packet Scheduler-0000)
[19,6] 86-F7-20-52-41-53 (Miniport réseau étendu (Moniteur réseau)-QoS Packet Scheduler-0000)
[20,6] 00-1E-EC-FD-D9-ED (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.0)-QoS Packet Scheduler-0000)
I have rebooted (without unlock because it is writed "You have used your
allocation of unlock codes") and there are a new id now:
GlidosID: D323D08F5BB218390C8EEC321E195DB5
After Reboot
[4,6] 06-F7-20-52-41-53 (Miniport réseau étendu WAN (IPv6))
[5,6] 04-96-20-52-41-53 (Miniport WAN (IP))
[8,6] 04-96-20-52-41-53 (Miniport réseau étendu (Moniteur réseau))
[17,6] 06-F7-20-52-41-53 (Miniport réseau étendu WAN (IPv6)-QoS Packet
Scheduler-0000)
[18,6] 04-96-20-52-41-53 (Miniport WAN (IP)-QoS Packet Scheduler-0000)
[19,6] 04-96-20-52-41-53 (Miniport réseau étendu (Moniteur réseau)-QoS
Now
You have used your allocation of unlock codes.
and i do not make a new unlock
After Shutdown (WITHOUT UNLOCK)
Scheduler-0000)
Another GlidosID: 0A73652571309ECB2B4B4FA86B93DFCB
after reboot.
What to do ?
Thanks
[4,6] 12-E0-20-52-41-53 (Miniport réseau étendu WAN (IPv6))
[5,6] 12-E0-20-52-41-53 (Miniport WAN (IP))
[8,6] 12-E0-20-52-41-53 (Miniport réseau étendu (Moniteur réseau))
[17,6] 12-E0-20-52-41-53 (Miniport réseau étendu WAN (IPv6)-QoS Packet
Scheduler-0000)
[18,6] 12-E0-20-52-41-53 (Miniport WAN (IP)-QoS Packet Scheduler-0000)
[19,6] 12-E0-20-52-41-53 (Miniport réseau étendu (Moniteur réseau)-QoS
Try this version of Glidos.exe.
Yes !
Now i can restart and shutdown with the same Glidos ID
I must unlock VDos32 at each time. (Without connection it is impossible).
Thanks
And BRAVO !!!
Great news. 😁 I'll fix VDos32 too soon.
Fantastic !
If I install a new version Glidos do ID Glidos will change and should I unlock?
(on the same PC)
For any one PC, all the versions of Glidos that give a stable ID should give the same ID.
