Reply 120 of 2670, by Falcosoft
- l33t
Now that I know what your situation is, I must say it IS applicable to yours. 😀
You only need 3 instances of FSMP and 2 software cables. First set the 1st instance of FSMP to output to Midi yoke 1. Set the 2nd instance of FSMP to get Input from Midi Yoke 1 and send output to Midi yoke 2. Set the 3rd instance of FSMP to get Input from Midi Yoke 1 and send output to HW MIDI-out where your SC-55 is. Finally set SCVA to get input from Midi-yoke 2. You can individually set Volume/Mute/Controllers/anything from the 3 instances of FSMP. The 1st set the global values the 2nd and 3rd can set SCVA and SC-55 values respectively.
