Reply 1080 of 1716, by Falcosoft
- Oldbie
Meowdori wrote on 2020-06-17, 07:16:EDIT: Small bug report for version 5.7 (32bit):
When playing a file, using a VSTi (specifically S-YXG50 in this particular tested case), going to device setup menu and repeatedly (rather quickly) untincking/ticking the "Use BASS" checkbox at least 3 times results in a memory protection fault (recoverable, without a crash). Tested OS is Windows XP Pro SP3 32bit.
Do not do this 😀
It's because when you untick 'Use Bass' FSMP tries to unload the whole Bass infrastructure (Bass_VST.dll, Bassmidi.dll, Bass.dll) in order not to cause trouble for normal WinMM Midi out ports that want to use Bass libraries themselves (e.g. ver 1.x of VirtualMidiSynth, Kode54's VST Midi Driver etc.). But some VST plugins need substantial time to properly unload (there are even plugins that cannot be properly unloaded by Bass_VST). If Bass is stuck and you want to initialize it again unexpected problems can happen.
Depending on VST plugin similar problems can also happen when you quickly and repeatedly start/stop plugin in either some of the VST Effects or VST Instrument dialog.
