First post, by robertmo
just copy your windows folders
run in safemode and remove all devices
manually add ACPI
windows will redetect everything
HAPPY VACATIONS 😀
Reply 3 of 12, by Firtasik
Thanks!
Sadly, Win98 refuses to load with WHPX :
WHPX: Failed to emulate MMIO access with EmulatorReturnStatus: 2
WHPX: Failed to exec a virtual processor
11 1 111 11 1 1 1 1 1 11 1 1 111 1 111 1 1 1 1 111
Reply 10 of 12, by torpedo
@robertmo
Thank you for the build.
Just a quick question. I followed the wiki and used ac97 with the sigmatel driver (Topic 80660) and I have a small audio delay in UT99 demo opengl renderer (also in Motorhead). I'd say something like 0.3-0.5 second. https://siasky.net/AAAfwMMwCVEI0DCGJv26slp7iL … ipnCqAvms-YYKUA
You can hear the UI button sound effects and the slight lag.
Is this normal?
Host OS Win10+whpx, guest OS win98. Normal guest OS sound effects have no delay (like the soundclicks when opening a folder).
