Reply 1 of 12, by Firtasik
- Oldbie
Are those archives corrupted?
11 1 111 11 1 1 1 1 1 11 1 1 111 1 111 1 1 1 1 111
Reply 2 of 12, by robertmo
- l33t++
just rename to qemu_700_glide20220710_2_2.zip.001
Reply 3 of 12, by Firtasik
- Oldbie
Thanks!
Sadly, Win98 refuses to load with WHPX :
WHPX: Failed to emulate MMIO access with EmulatorReturnStatus: 2
WHPX: Failed to exec a virtual processor
Reply 4 of 12, by robertmo
- l33t++
you generally have to do all drivers installations and settings in tcg mode. and once it works ok you can move to whpx.
Reply 5 of 12, by Firtasik
- Oldbie
Sadly, It didn't help.
Reply 6 of 12, by ramesis
Tested, worked. Tried FIFA RTWC98, runnable but sluggish.
Reply 7 of 12, by robertmo
- l33t++
Firtasik wrote on 2022-07-16, 17:21:Sadly, It didn't help.
you can always install a fresh one 😀
Reply 8 of 12, by robertmo
- l33t++
ramesis wrote on 2022-07-23, 03:26:Tested, worked. Tried FIFA RTWC98, runnable but sluggish.
whpx/haxm/tcg?
fullscreen/window?
vsync on/off?
how many fps the console shows?
your cpu?
your gpu?
Reply 9 of 12, by robertmo
- l33t++
ramesis my guess is you haven't run the glide version but the software one
Reply 10 of 12, by torpedo
@robertmo
Thank you for the build.
Just a quick question. I followed the wiki and used ac97 with the sigmatel driver (Topic 80660) and I have a small audio delay in UT99 demo opengl renderer (also in Motorhead). I'd say something like 0.3-0.5 second. https://siasky.net/AAAfwMMwCVEI0DCGJv26slp7iL … ipnCqAvms-YYKUA
You can hear the UI button sound effects and the slight lag.
Is this normal?
Host OS Win10+whpx, guest OS win98. Normal guest OS sound effects have no delay (like the soundclicks when opening a folder).
Reply 11 of 12, by robertmo
- l33t++
what about sb16?
Reply 12 of 12, by robertmo
- l33t++
you can try modifying latency in this line
-audiodev dsound,id=dsound,driver=dsound,latency=20000
