A NOT-SO EPIC Dual Pentium Pro Build
Reply 160 of 167, by Irinikus
The Oxygen 202's a cool video card which is 100% compatible with this system, as it's from the 1996 era, however it has one fatal flaw which renders this system pretty much useless for classic gaming, as it doesn't support 256 colours!!!
This system seems to be very fussy with graphics cards, and doesn't like my Matrox millennium II, so I'm considering one of these to hopefully drive the 2D graphics in this system:
An ATI 3D Rage II 8MB (4MB on card + 4MB)
317.27 KiB
It's from the 1996 era, so it should hopefully be compatible with this system. (I really hope so!!!)
164.36 KiB
And it supports 256 colours @ 640x480:
128.83 KiB
And it has windows NT4 driver support:
39.51 KiB
YouTube
Reply 161 of 167, by Irinikus
The lowest the Oxygen 202 will do @ 640x480 is 32768 colours, and this won't do for classic gaming! 🙁
1.67 MiB
YouTube
Reply 162 of 167, by chinny22
ok fine I guess I'll "let you" swap out the Oxygen 😉
Shame as it's such a unique card, but your right not much point if it makes the PC useless for gaming.
The Rage is somewhat correct as well as dual socket servers would use it for onboard video, newer servers but servers all the same.
Reply 163 of 167, by Irinikus
chinny22 wrote on 2024-03-14, 22:16:
Thanks! 😀
I'm all for other suggestions if there are any, "period correct cards which can push 1280x1024 in true colour and 640x480 in 256 colours".
YouTube
Reply 165 of 167, by Irinikus
luckybob wrote on 2024-03-16, 15:02:
my board works great with a matrox G200.
Matrox G200 PCI 8MB video card, quick test
Thanks very much for the link! 😀
The system's still suffering from a considerable amount of instability, especially after it's been running for a while!
I think that it may require a re-cap as well as an inspection with a fine-toothed comb (Microscope)!
I don't currently have the equipment (re-work station with microscope and oscilloscope) necessary to carry out these tasks, so I'll have to put this on hold until I do.
I'm not willing to throw more money at this one until I can get it to run stably!!!
Ultimately this little hobby will convert from collecting to repairing, which is fine by me!
YouTube
Reply 166 of 167, by luckybob
You might want to fiddle around with the cpu card. if it isnt EXACTLY in the right position, it can cause errors. There is a big reason they didnt do this on other boards.
Reply 167 of 167, by Irinikus
luckybob wrote on 2024-03-17, 15:33:
Agreed!
The CPU card isn't the best of designs, as you have electrolytic capacitors sitting right up against the VRM heatsinks, which will reduce their life span as the heat sinks on this card get pretty hot!
1.8 MiB
1.4 MiB
1.15 MiB
I'll also need to find out how to give all of the contacts in the slots a deep clean. (The board as a whole for that matter!)
I'll need to go over this board with a fine-toothed comb in a series of logical steps.
YouTube
