First post, by maw
ok. after talking in some threads about my dos hardware here now the introducing of the desktop one in the current config:
• CPU : Intel Pentium1 MMX @ 1 x 200 MHZ
• Memory : 1x64MB SD-Ram
• Video Card : 3dfx Voodoo3 2000 PCI 16MB
• Hard Drive : 1x 80GB IDE (Maxtor)
• Optical : CD-Rom Drive
• Floppy disk : 1x 3½-inch (1,4MB), 1x 5,25-inch (1,2MB)
• Motherboard : Gigabyte Technology GA-5SMM mATX SUPER SOCKET 7, 2x ISA, 3x PCI
• Sound : SoundBlaster Awe64 Gold CT4390 PnP 4MB (ISA) (SoundBlaster 16 CT1770 DSP4.05 SCSI 16-Bit ISA Sound Card w/ DSP (ISA) + YAMAHA DB60XG MIDI Wavetable extension*)
• Case : Standard Desktop ATX case (HEC 7106WW Beige)
• Monitor : Lacie electron 19 blue III, 19-inch
• Operating-System : MS-DOS 6.22, Windows98
* not in use ATM
UPDATE Feb 2018
Years have passed and the specs have changed. Here the 99% final.
• CPU : AMD K6-2 @ 500MHZ
• Memory : 1x128 MB SD-Ram PC133
• Video Card : 3dfx Voodoo3 2000 AGP
• Hard Drive : 1x 8GB DOM
• Optical : CDRW-Drive, DVD ROM Drive
• Motherboard : Asus P5A
• Network : Intel PRO1000 GT
• Monitor : Nec MultiSync 1970NC
• Operating-System : Windows98
Looking forward to the new Simmconn AWE64 batch.
All the stuff is now hanging on my OmniView PRO3 (F1DA104Z) KVM switch. I don't want to have x keyboards and mice on the desk. The Switch will serve later on also my new 486 box and my A4000T.
1.23 MiB
783.4 KiB
1.08 MiB
979.24 KiB
BOX#1: ASUS P5A | Pentium1 200 | 64MB PC100 | Voodoo3 AGP | AWE64 GOLD + SIMMConn| 16GB Kingspec DOM | DVD Drive | Dos 6.22 + Win98
Reply 1 of 13, by Liqu1d82
Congratulations, nice build - I have a Voodoo 3 2000 too, and I thought I'd use it for my FreeDOS machine instead of Voodoo + S3 ... but in the end I keep on the classic double.
Beautiful case desktop!
Without change something sleeps inside us, and seldom awakens. The sleeper must awaken.
http://liqu1d82.tumblr.com [My Tumblr] // https://twitter.com/Liqu1d82 [My Twitter]
Reply 3 of 13, by maw
soon upgrade with a P5A board.
thanks. Got it new on newegg. Was surprised to get a bigger case new in retro design and beige to a good price.
Reply 4 of 13, by Splinter
I really like that set up, especially the nice looking case.
Congrats!
http://www.compufixshop.com
Main rig Ryzen 2600X Strix RX580 32GB RAM
Secondary rig FX8350 GTX960 16GB RAM
Reply 6 of 13, by maw
a little update 😀
Reply 7 of 13, by maw
Hmm I tested now a bit around and installed Wing Commander 4 + Win9x patch. The DOS version runs flawless. The Win9x exe makes some trouble. The sound in the video is cracked. So I thought maybe slow CPU issue and I switched to a K6-2 500 and upgraded the memory at the same time to 128MB. Same issue. Any ideas? I will keep the CPU and mem now in that box 😀
Reply 8 of 13, by phosgene
I like it, the gold heat sinks on the AWE64 Gold are a nice touch. 😀 Not sure what to do about the FMV sound issues you're having, maybe install the 9x DVD version, or update the Windows sound drivers?
Reply 9 of 13, by NostalgicAslinger
I also have cracked sound with the 9x Version of WC4. The same AWE64 Gold, but a Intel Slot 1 System. So maybe it's a problem with the soundcard? I use the latest driver from philsomputerlab.
Or a problem with DirectX Acceleration? DirectX 9.0c is installed. Maybe interesting to test with this setting:
    33.17 KiB
Reply 10 of 13, by maw
Will test later on tonight. I have the same problem also with Wing Commander Prophecy 😢 There videos even jump
Reply 11 of 13, by Shagittarius
I remember this occurred even at the time for Prophecy. There is either a patch or a fix though, so fear not. Sorry I can't remember the details but I have recently run this game, and also ran it back near the time of release and it always had the video playback skipping issue. But it can be fixed.
Oh, it's just the sound acceleration, or apparently there is a patch, use at your own risk:
https://www.wcnews.com/wcpedia/Video_Skip_Patch
Reply 12 of 13, by NostalgicAslinger
But no patch for the CD Version of WC4 in Windows 9x. Reducing the sound acceleration should solve the problem.
Reply 13 of 13, by maw
Shagittarius wrote:
Works like charm. Totally forgot about. Thanks
It makes it worst here. Videos doesn't skip just the sound is bad like when you play in dosbox and have the wrong settings or not enough cpu power.
