Reply 20 of 45, by mastergamma12
- Member
Put some more games on the machine.
That's an excellent selection of games. Your guaranteed hours of fun.
How does XP run with the six cores. Does it ignore five of them?
RedCharles wrote on 2020-12-29, 19:40:How does XP run with the six cores. Does it ignore five of them?
All XP versions will run as many cores as you have, if you use more than one physical CPU I believe you need to get the enterprise version.
XP home can use 1 cpu socket with multiple cores and XP pro can use 2 cpu sockets with upto 32 cores for 32bit and upto 64 cores with XP 64
One core limitation is for 98, XP can use up to 32 cores.
Thanks for the replies.
And on the topic does XP ignore 8gb out of 12gb of ram then? Or does the 12gb of ram cause problems for XP?
I'm considering a similar build for myself.
With 32 bit addressing it shouldn't matter if you have more than 4gigs since it can't address it
RedCharles wrote on 2020-12-29, 21:14:And on the topic does XP ignore 8gb out of 12gb of ram then? Or does the 12gb of ram cause problems for XP?
It's the same, like with 98 and multi core CPUs. XP just ignores anything above 4GB. I have dualboot XP/7 on my laptop with 12GB of RAM, and XP just see and can use only 4GB. There's no problems with excess amount of RAM in XP.
It sees all 6 cores and 12 threads
As for ram, xp only sees 2gb's while 7 sees all 12gb's
Have you had any compatibility issues with early 2000s games?
RedCharles wrote on 2021-01-01, 09:20:Have you had any compatibility issues with early 2000s games?
Only game so far was Planet of the Apes 2001, graphic issues.
That game runs fine on my 98 rig.
I threw a USB 3 card in here and took out the wifi card as it didn't support XP so I'm just using a USB one now. Now the front panel usb ports run at USB 3 speeds. Also threw quite a few more games on XP and 7.
Ended up inserting another wifi card in.
I was able to get the leaked build of Windows 11 to run on here.
Sweet. How does it run?
chrismeyer6 wrote on 2021-06-25, 22:18:Sweet. How does it run?
Thing flies
Is there an advantage running a I7 980X over say a Xeon X5675?
Grem Five wrote on 2021-06-27, 11:41:Is there an advantage running a I7 980X over say a Xeon X5675?
On this machine, very much, this board doesn't support Westmere Xeons period, I tried everything I could think of to get my W3680 to work and in the end, I ended up using a 980x.
Now if this was any other X58 board, then no.
I also tried the version of 11 that was released today, it still works.
