Reply 20 of 33, by mastergamma12
Put some more games on the machine.
file.php?mode=view&id=96982
    417.22 KiB
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Reply 23 of 33, by Shagittarius
RedCharles wrote on 2020-12-29, 19:40:
How does XP run with the six cores. Does it ignore five of them?
All XP versions will run as many cores as you have, if you use more than one physical CPU I believe you need to get the enterprise version.
Reply 25 of 33, by Srandista
One core limitation is for 98, XP can use up to 32 cores.
Socket 775 - ASRock 4CoreDual-VSTA, Pentium E6500K, 4GB RAM, Radeon 9500@9700, ESS Solo-1, Win 98/XP
Socket A - ASRock K7S41GX, AMD Athlon XP 3000+, 512MB RAM, GeForce4 Ti4200, SB Live, Win 98
Reply 28 of 33, by Srandista
RedCharles wrote on 2020-12-29, 21:14:
And on the topic does XP ignore 8gb out of 12gb of ram then? Or does the 12gb of ram cause problems for XP?
It's the same, like with 98 and multi core CPUs. XP just ignores anything above 4GB. I have dualboot XP/7 on my laptop with 12GB of RAM, and XP just see and can use only 4GB. There's no problems with excess amount of RAM in XP.
Reply 29 of 33, by mastergamma12
It sees all 6 cores and 12 threads
As for ram, xp only sees 2gb's while 7 sees all 12gb's
Reply 31 of 33, by mastergamma12
RedCharles wrote on 2021-01-01, 09:20:
Have you had any compatibility issues with early 2000s games?
Only game so far was Planet of the Apes 2001, graphic issues.
That game runs fine on my 98 rig.
Reply 32 of 33, by mastergamma12
I threw a USB 3 card in here and took out the wifi card as it didn't support XP so I'm just using a USB one now. Now the front panel usb ports run at USB 3 speeds. Also threw quite a few more games on XP and 7.
Reply 33 of 33, by mastergamma12
Ended up inserting another wifi card in.
