First post, by Xeen
Hello everyone,
I came across this motherboard recently which has no manufacturer or model on it, can anyone help me to ID it so that I can find the latest BISO and manual online?
Furthermore, it came with 4 EDO ram sticks which are 32MB in total and always gives "ON BOAR PARITY ERROR - ADDR (HEX) = (OOOO:0002) SYSTEM HALTED" error every time I save BIOS changes. If the error shows up then I can't get into BIOS anymore until clear BIOS settings by removing CMOS battery...
After removing CMOS battery several times I figure out that I can bypass the error by disabling "Memory Parity Error Check", but can it cause other issues like instability?
Can I clear BIOS without removing the battery, these jumpers look suspicious?
