First post, by Xeen
Hello everyone,
I came across this motherboard recently which has no manufacturer or model on it, can anyone help me to ID it so that I can find the latest BISO and manual online?
1.47 MiB
Motherboard
1.46 MiB
Motherboard
Furthermore, it came with 4 EDO ram sticks which are 32MB in total and always gives "ON BOAR PARITY ERROR - ADDR (HEX) = (OOOO:0002) SYSTEM HALTED" error every time I save BIOS changes. If the error shows up then I can't get into BIOS anymore until clear BIOS settings by removing CMOS battery...
After removing CMOS battery several times I figure out that I can bypass the error by disabling "Memory Parity Error Check", but can it cause other issues like instability?
1.88 MiB
BIOS
686.77 KiB
RAM
Can I clear BIOS without removing the battery, these jumpers look suspicious?
1.8 MiB
Jumper
Reply 2 of 5, by fitzpatr
https://stason.org/TULARC/pc/motherboards/A/A … -486-V433S.html
The A at the bottom left of the board indicates that it is an AOpen/Acer board.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 4 of 5, by fitzpatr
The sticks that you are using contain 2 1M(b)x4 chips. This means that each stick of yours is 1MB, for a total of 4MB. (32Mb, as it happens) b = bit, B = byte (8 bits).
The cause of the Parity error is that the manual specifies "1M x 9". The 9 indicates sticks of RAM with 9 Chips. 8-chip RAM is non-parity, 9-chip RAM is Parity. Later sticks condensed this down to 2-chip (non-parity, which you have), and 3-chip (Parity.
Since this motherboard seems to want Parity RAM, I'd look for 30-pin SIMMs with either 3 or 9 chips.
486 Build
