Socket 7 - Intel Ultimate
First post, by RichB93
I need to post pictures, but here's my latest project...
- A SOYO SY-5BT Intel 430TX chipset AT motherboard modified for low voltage to run a…
- Intel Pentium 266MHz ‘Tillamook’ mobile CPU, clocked at 300MHz (4x75MHz FSB)
- 64MB (4x16MB) EDO RAM
- Diamond Stealth 3D 2000 Pro S3 ViRGE/DX 4MB graphics card
- Guillemot Maxi Gamer 3D 3dfx Voodoo 4MB 3D accelerator
- Creative SoundBlaster AWE32 with 8MB (2x4MB) of SoundFont RAM
- 3Com EtherLink 10/100 PCI network card
- 10GB Quantum Fireball HDD
- LG 48x CD-ROM
This is (in my eyes at least) the ultimate Socket 7 setup - you can get faster AMD CPUs and chipsets from others, but I’ve always had much more of an affinity for Intel and never really cared for AMD CPUs (or VIA/SiS chipsets for that matter). I did toy with using an ATi All-in-Wonder PRO 8MB card, and even played a little ATi CIF powered WipEout, but figured that the S3 was the better choice (not speed wise, of course, but just overall).
I'll pop some pictures up at some point but as you can imagine this looks like pretty much any other socket 7 build - still chuffed with it however!
Reply 1 of 20, by bloodem
Great build, except for that Voodoo 1, which is a severe bottleneck for the Tillamook, even more so when overclocked. 😀
I would save the Voodoo 1 for a Pentium MMX 166 build or something like that, and go with a Voodoo 2 (or even a Voodoo 3) for this one.
2 x PGA132 / 5 x Socket 3 / 4 x Socket 7 / 6 x Super Socket 7 / 5 x Slot 1 / 3 x Slot A
5 x Socket 370 / 5 x Socket A / 1 x Socket 478 / 2 x Socket 754 / 3 x Socket 939 / 4 x LGA775 / 1 x LGA1155
Current rig: Ryzen 5 3600X
Backup rig: Core i7 7700k
Reply 2 of 20, by Joseph_Joestar
Nice system! Very similar to mine though with a more powerful CPU.
I'm mostly using my rig as a DOS gaming machine, but I did try out a few Windows 3D accelerated games as well since I recently got a Voodoo1. It would be interesting if you could post some benchmarks to compare.
PC#1: Pentium MMX 166 / Soyo SY-5BT / S3 VirgeDX / Voodoo1 / OPTi 82C930 / AWE64
PC#2: Celeron 466 / Abit ZM6 / Voodoo3 / AWE64 / YMF744 / SC-155
PC#3: AthlonXP 1700+ / Abit KT7A / GeForce4 / SBLive / ALS100
PC#4: Athlon64 3700+ / DFI LanParty / 9600GT / X-Fi Titanium
Reply 3 of 20, by Joseph_Joestar
bloodem wrote on 2021-06-21, 08:43:
It might be a bottleneck even for an MMX 166.
I ran some benchmarks and compared them to this Anandtech review from 1998. Somehow, I'm getting similar frame rates as their Pentium II 266 system. Maybe some of the patches and drivers that weren't available at that time helped, but it's still evident that the Voodoo1 is what's holding down the performance.
Reply 4 of 20, by bloodem
Joseph_Joestar wrote on 2021-06-21, 09:48:
Yes, it's very likely that this is the case. The Voodoo 1 was initially designed around the Pentium 90 era. In an interview that I saw, Gary Tarolli actually mentions how he realized that a Pentium 90 was powerful enough to handle the compute intensive geometry phase (i.e. the "transform" part, that handles all the 4x4 matrix operations such as rotation, translation, scaling, projecting, etc).
Since a Pentium MMX 166 with its doubled L1 cache is more or less equivalent to a Pentium 200... it's safe to assume that it will also be bottlenecked by the Voodoo 1.
Now, even so, I personally would not build a socket 7 system with a CPU that is slower than the Pentium MMX 166... I feel like the Pentium MMX 166 offers great Windows 95 performance and if you go for a Pentium 100 or lower, the experience is not as good.
Reply 5 of 20, by RichB93
Thanks! I like the Voodoo as it seems to work well with older games which is mainly what this system will be aimed at. I have another system with Voodoo2's and another with a Voodoo3. With that being said, I wasn't aware as to just how slow a CPU is the optimal match for it! I know that when the 3dfx became available to most people, the P166 was the latest and greatest, but I suppose it makes sense that the card was also designed to work well with slower CPUs.
Joseph_Joestar wrote on 2021-06-21, 09:25:
I just saw your thread when I came to check on this! I'll definitely be up for doing some benchmarks to compare; one thing I did notice compared to the 233 MMX that I previously used was that the system was a good deal faster in Carmageddon II - it actually becomes playable!
Reply 6 of 20, by H3nrik V!
bloodem wrote on 2021-06-21, 13:05:
IIRC my friends and I started getting Voodoo 1s in the era where we had Pentium 166, 166MMX and 233MMX. According to Wikipedia, Voodoo 1 launched in autumn 1996 and the Pentium MMX in January 1997, so I would call Voodoo 1 and MMX pretty period-equivalent ..
Reply 7 of 20, by bloodem
Yeah, that is completely true, but it has nothing to do with the card being a bottleneck for those CPUs or not. 😀
Back then a Voodoo was mind blowing anyway, nobody even considered the bottleneck factor, because there wasn't anything else to compare it to 😁
When the Voodoo came out, everybody was on S3 Trios, Virges & similar video cards. Once you added a Voodoo and saw GLQuake for the first time, the last thing on your mind would've been "gee, even if this card is blazing fast compared to what my experience has been so far, is it possible that it is still a bottleneck for my current CPU?" 🤣
Reply 10 of 20, by H3nrik V!
From this thread, it seems possible to have L2 working with a Tillamook Tillamook 266MHz and working L2 cache?
Reply 11 of 20, by RichB93
Hezus wrote on 2021-06-23, 10:42:
How do you get a mobile CPU working on a normal socket 7 board? And does the l2 cache work?
The appropriate modifications to the CPU (which I've posted in the thread linked below), plus modifying the motherboard to run CPUs at a lower voltage. Technically the I/O voltage is over the ranges defined by Intel for Tillamook, but I've been using it for many hours with no stability issues.
H3nrik V! wrote on 2021-06-23, 11:06:
Yup! Many had found some stuff before me on there, I found what I think is the last piece of the puzzle in grounding the AL1 pin to ensure the chip uses split-rail voltages.
Reply 12 of 20, by Jasin Natael
Great build Tillamook is a bucket list CPU for sure.
I would definitely go for a Voodoo 3/Voodo2SLI option though.
And I have to say...K6-3+ smashes the Pentium MMX....of course i AM a AMD fanboy and happy to admit it 😉
Edit: Pass on the Voodoo 3/2SLI, maybe go with a Banshee option? Should do well on that CPU, maybe less money too.
Reply 13 of 20, by bloodem
Jasin Natael wrote on 2021-06-24, 15:47:
Not so much... a Banshee is still a bottleneck even @ 640 x 480 in many games (like GLQuake, for example).
Of course, it is DEFINITELY much better than a Voodoo 1 in every way (except compatibility).
Reply 14 of 20, by Jasin Natael
bloodem wrote on 2021-06-24, 18:33:
This makes sense. I've never actually owned one, just figured it would slot in nicely between a single Voodoo 2 and a Voodoo 3.
Maybe a single Voodoo 2 with a decent 2D card would be ideal. Gets pricey though if you don't already have the hardware.
Just seems a waste to use a Voodoo 3 on such a lowly Pentium MMX, not to insult the rather special Tillamook but it is what it is.
Reply 15 of 20, by chinny22
Jasin Natael wrote on 2021-06-24, 20:12:
I'd agree with this.
I've got a Banshee on a Slot A 600Mhz and plays NFS3 just as well as the P3 600 with V2SLI fine so can't imagine a Socket 7 rig pushing the card too much either.
Not disagreeing with bloodem, if all your chasing is raw speed then V2 or better will give even better results but now its the Voodoo been under utilised.
Reply 16 of 20, by RichB93
I think a Banshee isn't a bad shout but finding a PCI one, and at a reasonable price isn't getting any easier these days. I have a nice Gigabyte GA-630 Banshee spare currently, but it's AGP. The Voodoo2 is a bit wasted on this system too I think; I'm happy with my two in SLI in a P3 machine (alongside a Rage Fury Maxx). I like having a ViRGE in there just as another 3D accelerator, although admittedly I only use it really to play Terminal Velocity and Screamer. As mentioned I did have an ATi card in there and the ATi CIF accelerated WipEout runs well, but as a single exclusive game it wasn't really worth it. Whilst I know the Tillamook throws the authenticity of the machine out of the window somewhat, I like that the original Voodoo is authentic to the build in general. I'd love to find a 6MB model if possible, even though I know that the extra 2MB RAM doesn't really make any difference to most games targeting the Voodoo1.
Reply 17 of 20, by Joseph_Joestar
RichB93 wrote on 2021-06-25, 11:26:
Any Voodoo1 with more than 4 MB becomes less compatible with early Glide games, which kinda defeats the point of having that card.
Reply 18 of 20, by RichB93
Joseph_Joestar wrote on 2021-06-25, 11:34:
I was not aware of that; thanks for the heads up! I guess I don't need to feel too bad about having a 4MB card then! 😜
Reply 19 of 20, by Joseph_Joestar
RichB93 wrote on 2021-06-25, 15:13:
The incompatibilities are mentioned on the Vogons wiki.
Also, LGR has a video which showcases what happens when you use a Voodoo1 with > 4 MB.
