First post, by ettin
hey,
quick question,
I have a Roland Mt 32 and a 486 DX4 100 with a Sound Blaster 16 (CT1740)
Can someone tell me what cable I need?
Joystick-Midi yes?
Do I also need a breakout box?
cheers!
Reply 1 of 57, by 5u3
Joystick-Midi yes?
A simple MIDI cable for the joystick port will do.
Breakout boxes are only needed for more sophisticated MIDI interfaces.
Reply 4 of 57, by Kippesoep
Use the L/R mono outputs. They're standard 5.5mm jack outputs. With a splitter and some creative use of extension/conversion cables, you can make it into a 3.5mm stereo jack.
MIDI out only passes the raw MIDI data along to another MIDI instrument.
And yes, that is the right cable. And no, you won't need any drivers for it.
Reply 6 of 57, by dvwjr
ettin wrote:
So the output ill be getting is mono?
am I look for a cable with two 5.5mm male connectors and two 3.5mm RCA male connectors on the other end?
No, stereo.
To get the audio output of the MT-32 which uses the older RCA 1/4" phono jacks for which you would need something like the HOSA CMP-159 Mini to 1/4" Phone Stereo 10ft cable to connect your Roland MT-32 to another one of your PC mini-jack 1/8" audio inputs.
dvwjr
Reply 8 of 57, by Kippesoep
It outputs a left channel and a right channel using separate 5.5mm jacks. One of them corresponds to the white RCA phono jack and the other to the red one.
My site: Ramblings on mostly tech stuff.
Reply 9 of 57, by ettin
Hey,
Im new to all this got a few more questions.
My roland arrived a few days ago...
We just moved house a few weeks ago and where the computers are there are no power points.
Its a bit of a mess right now. and ive got a few powerboards with surge protectors and extension cords all over the place running 3 PCs.
Anyway I plugged the roland into one of the powerboards. Started running lands of lore .... and aswell as the incredible roland sounds i was hearing. I got a whole lot of voltage noises coming through the speakers ...then everything went nuts. computers powered off. then the whole side of the room.....power went off...
When i unplug one of the powerboards. its all good. i dont have a problem...
Also, im using the MONO OUTPUT L and R connections in the back of the roland ...... two 6.5mm connections into two RCA stereo connections.
I have it plugged into a stereo/hifi system, and im only getting one channel, like the left is working and not the right.
any ideas?
Is it because the output says mono ? and im using a stereo system?
Reply 12 of 57, by Qbix
Rank DOSBox Author
DOSBox Author
AC Power ? that part you can't wire wrong. The DC part I don't know. Didn't know it was possible to wire that wrong
Water flows down the stream
Reply 13 of 57, by ettin
Qbix AC Power ? that part you can't wire wrong. The DC part I don't know. Didn't know it was possible to wire that wrong
So yesterday, Im playing Lands of Lore on my 486, the MT-32 seems to be working fine. I crash back to MS-DOS prompt, and leave the 486 and roland on......
So i walk away....
Heard a terrible noise come out of the speakers i have connected to the Roland. came back ..roland was off. and the 9Volt 1000 ma power adapter was REALLY hot and there was a terrible smell coming from it.
Power Adapter Dead.
Dodgey Electrics/Powerpoints in this house? Dodgey Power adapter or something else?
Reply 14 of 57, by Kippesoep
Might very well have been a flaky adapter. The original power adapter (a Roland ACB-nnn, I think) supplies only 650mA as it says on the back of the unit. It can become quite warm, but shouldn't burn out.
Reply 15 of 57, by dvwjr
The Roland MT-32 that I bid and won on eBay has a Roland ACB-120 DC power supply (1200mA @9V DC). The Roland MT-32 docs indicates that power consumption is 650mA @9V DC. The Roland ACB-120 DC-connector has its polarity oriented differently than most other power-supplies with (+) sleeve, (-) tip. Most other DC power supplies have (-) sleeve, (+) tip.
Be careful...
dvwjr
Reply 16 of 57, by Great Hierophant
Be careful...
dvwjr
That particular power supply can handle most Roland devices, including the '32. I use one myself for my '32 (MT or CM).
Reply 17 of 57, by acefox
I, too, have just received a Roland MT-32 from eBay, and am wondering how best to connect it to my PC, albeit in my case I want to connect it to a P4 running DosBox on Windows XP.
Connecting MT-32 with a MIDI-USB cable for DosBox?
The MIDI-joystick cable mentioned in this thread seems like it would work with my SB Live! Value card which has a MIDI/joystick port. But I was also wondering if using a MIDI-to-USB converter cable directly to my PC might be a better option? And if so, what would I need to do to get the MIDI to be transmitted through the USB port?[/url]
Reply 18 of 57, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
uhm, you'd need a midi-to-usb converter and the midi cable for connecting the mt32 to the converter.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
