First post, by MattA
- Newbie
I actually went to play some old games tonight, and everything seemed to work fine right up until my MT-32 remained completely inactive.
I have it connected via a USB-MIDI adapter on my Windows 10 PC. I run all my games through DOSBox and have never had an issue playing any of them before. I tried different USB ports for the MIDI adapter, unplug/replug the MT-32, check all settings, make sure the device was set correctly in options, etc. The USB-MIDI adapter shows activity whenever any of the games are started, but the MT-32 just sits there with its default screen, looking at me.
Because of this, I finally downloaded and started up Munt, which works perfectly well. Everything sounds as it should and works properly. That said, I'm going to miss playing games on the actual MT-32 hardware. It's a sad day. 🙁
If anyone has bumped across this and has any ideas, please let me know. Otherwise, I see a lot of emulation in my future.
