MattA wrote on 2023-12-17, 05:17:
If anyone has bumped across this and has any ideas, please let me know.  Otherwise, I see a lot of emulation in my future.
Oh, well. If you have a retro rig, you can still use an Raspberry w/ mt32-pi software in place of your real MT-32.
I do that, too and I'm quite happy with it. I do use my real MT-32 mainly for testing, if at all, not playing games.
The real MT-32 also serves as a license, essentially, so I can use a substitute without regrets.
I'm also a bit proud to be an MT-32 owner, of course. It's good to know there's a physical unit in the house, it helps to not to loose touch to reality in those days of emulation.
That being said, I believe the problem can be fixed, if there's any. Maybe it's something wrong with the MT-32's serial port.
A broken capacitor, broken diode, pull-up or pull-down transistor, some defect in the serial port UART..
The core electronics of the MT-32 is unlikely to be broken, I think. The control firmware should be okay if the display otherwise behaves normally.
So it can be fixed, eventually. Just takes time.
Btw, I do sometimes have issues with my USB MIDI cables, not sure why.
Their transmit LED (if any) sometimes don't blink when sending MIDI data from DOSBox.
It's a Linux system though, so there might ve other issues, too.
Also be careful, some cheap cables don't have opto-couplers or pull-ups/downs. Instead, they send 5v directly, which is bad.
Because MIDI via DIN port is a current-loop interface. There should always be opto-couplers.
http://midi.teragonaudio.com/tech/midispec/hardware.htm
On my mt32-pi build, I've implemented my own little interface with an opto-coupler, thus.
It's here: Re: Show us your custom Physical mt32-pi Builds
Re: Connecting Roland MT-32 to Modern PC?
That being said, MIDI and audio hats for Raspberry Pi should be available. Maybe even an mt32-pi hat.
Edit: I forgot to mention. I vaguely remember that the MT-32 and the normal MIDI devices have different channel assignments.
So better double-check this online. It might be possible that playing through a normal piano doesn't make a sound on MT-32.
Again, I merely vaguely remember something like that. I could be wrong, though.
