First post, by jonmell
Hi - have been running DOSBOX 0.74-3-3 just fine on my MacBook Air M1 / Apple Silicon. Now every time I try to Option-Enter or put fullscreen=true in preferences DOSBOX just quits. No dialog box / error message / nothing in the console as far as I can see.
The only thing I can think of is I recently upgraded to Monteray 12.4 (from 12.3). Anyone else seen this / have any suggestions?
I have posted my preferences file below but also renamed it and ran DOSBOX to create a vanilla one and I had exactly the same issue
# This is the configuration file for DOSBox 0.74-3-3. (Please use the latest version of DOSBox) # Lines starting with a # are co […]
# Lines starting with a # are comment lines and are ignored by DOSBox.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
# fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
# fullresolution: What resolution to use for fullscreen: original, desktop or fixed size (e.g. 1024x768).
# Using your monitor's native resolution (desktop) with aspect=true might give the best results.
# If you end up with small window on a large screen, try an output different from surface.
# On Windows 10 with display scaling (Scale and layout) set to a value above 100%, it is recommended
# to use a lower full/windowresolution, in order to avoid window size problems.
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
# (output=surface does not!)
# output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb.
# autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
# sensitivity: Mouse sensitivity.
# waitonerror: Wait before closing the console if dosbox has an error.
# priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
# pause is only valid for the second entry.
# Possible values: lowest, lower, normal, higher, highest, pause.
# mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the defaul value.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=opengl
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74-3-3.map
usescancodes=true
[dosbox]
# language: Select another language file.
# machine: The type of machine DOSBox tries to emulate.
# Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
# captures: Directory where things like wave, midi, screenshot get captured.
# memsize: Amount of memory DOSBox has in megabytes.
# This value is best left at its default to avoid problems with some games,
# though few games might require a higher value.
# There is generally no speed advantage when raising this value.
language=
machine=svga_s3
captures=capture
memsize=16
[render]
# frameskip: How many frames DOSBox skips before drawing one.
# aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!
# scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,
# then the scaler will be used even if the result might not be desired.
# To fit a scaler in the resolution used at full screen may require a border or side bars,
# to fill the screen entirely, depending on your hardware, a different scaler/fullresolution might work.
# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core: CPU Core used in emulation. auto will switch to dynamic if available and
# appropriate.
# Possible values: auto, dynamic, normal, simple.
# cputype: CPU Type used in emulation. auto is the fastest choice.
# Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
# cycles: Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# Cycles can be set in 3 ways:
# 'auto' tries to guess what a game needs.
# It usually works, but can fail for certain games.
# 'fixed #number' will set a fixed amount of cycles. This is what you usually
# need if 'auto' fails. (Example: fixed 4000).
# 'max' will allocate as much cycles as your computer is able to
# handle.
# Possible values: auto, fixed, max.
# cycleup: Amount of cycles to decrease/increase with keycombos.(CTRL-F11/CTRL-F12)
# cycledown: Setting it lower than 100 will be a percentage.
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
# nosound: Enable silent mode, sound is still emulated though.
# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
# Possible values: 1024, 2048, 4096, 8192, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=44100
blocksize=1024
prebuffer=25
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use
# (find the id with mixer/listmidi).
# Or in the case of coreaudio, you can specify a soundfont here.
# See the README/Manual for more details.
mpu401 = intelligent
mpubase = 0
mididevice = coremidi
midiconfig = 0
samplerate = 44100
mpuirq = -1
mt32.romdir = ~/DOSBOX
mt32.model = auto
[sblaster]
# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
# sbbase: The IO address of the soundblaster.
# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
# irq: The IRQ number of the soundblaster.
# Possible values: 7, 5, 3, 9, 10, 11, 12.
# dma: The DMA number of the soundblaster.
# Possible values: 1, 5, 0, 3, 6, 7.
# hdma: The High DMA number of the soundblaster.
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
# Possible values: auto, cms, opl2, dualopl2, opl3, none.
# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
# Possible values: default, compat, fast.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
# pcrate: Sample rate of the PC-Speaker sound generation.
# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
# Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. Can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
# serial1: set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq (optional).
# for directserial: realport (required), rxdelay (optional).
# (realport:COM1 realport:ttyS0).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
# Possible values: dummy, disabled, modem, nullmodem, directserial.
# serial2: see serial1
# serial3: see serial1
# serial4: see serial1
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms: Enable XMS support.
# ems: Enable EMS support.
# umb: Enable UMB support.
# keyboardlayout: Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
Mount c ~/DOSBOX
C:
#imgmount d "trek2/stjr1.dat" -t iso -fs iso
#imgmount d "trekcd/trek.cfg" -t iso -fs iso
PATH C:\WINDOWS;c:\tc\;c:\tc\bin
SET TEMP=C:\WINDOWS\TEMP
Reply 1 of 15, by TactikalKitty
Not sure if this will help, but M1 Macs in general have issues with displaying content in Fullscreen from applications that are not M1 Silicon optimized. I believe it has to deal with the way Apple now uses Dynamic Scaling. DosBox has this issue. This also broke Elder Scrolls Online as well. You have to run that game in Windowed Mode for instance otherwise it will load but you will be unable to provide any kind of input with a mouse.
Reply 2 of 15, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
you could try this build I did (I'm also the one who created the last release version) https://www.dropbox.com/s/kbrf5elbcu66kst/Dos … apshot.dmg?dl=0
This is using SDL2 via SDL12compat
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 15, by rodbrites
I got something here.
It is almost a full screen...
fullresolution=1920x1080
output=overlay
aspect=true
scaler=normal3x
Reply 6 of 15, by rodbrites
jonmell wrote on 2022-05-28, 14:31:
Hi - have been running DOSBOX 0.74-3-3 just fine on my MacBook Air M1 / Apple Silicon. Now every time I try to Option-Enter or p […]
[sdl]
fullscreen=false
fulldouble=false
output=opengl
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# appropriate.
# handle.
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=25
[midi]
mpubase = 0
midiconfig = 0
samplerate = 44100
mpuirq = -1
mt32.model = auto
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
Mount c ~/DOSBOX
C:
Hey! Got something here:
output=overlay
aspect=true
scaler=normal3x
Reply 7 of 15, by Dominus
DOSBox Moderator
Dominus wrote on 2023-01-04, 15:08:
Thanks for testing. Seems I need to go over my build scripts ;(
Took a while but I fixed my build. Problem was that I use a tool that puts all the required libraries in a subfolder and points the binary at it. The SDL12-compat library needs the SDL2 library but doesn't link to it, so the tool didn't add it to the libraries folder.
Reply 8 of 15, by ctelendil
rodbrites wrote on 2023-01-04, 15:26:
output=overlay
aspect=true
scaler=normal3x
[/quote]
Thank you so much rodbrites!
This fix also helped me. I've been running Dosbox 0.74-3-1 on my Macbook Pro for years, but this week I got a new Macbook M2 running Ventura.
When I hit opt-R to go full screen, the dosbox window stayed the same size but the rest of my screen went black.
The rodbrites build fixed that error. I'm on an Apple M2 pro running OS 13.0. Tested with the full screen with Oregon Trail, Dune 2, and Heroes of Might & Magic. All good.
Reply 9 of 15, by Burrito78
i'm running 0.74-3-3 on a M2 mini (2023) macOS Ventura 13.4 (22F66). Deleted my conf file for vanilla settings. When hitting Opt+Enter the DOSBox window just closes without any error message.
Thanks
Sound Blaster: From best to worst
Member of DOSBox Staging
Reply 13 of 15, by traderhut
SVN version doesn't support using a shift key (it appears to be reading the Mac's shift status directly - I had the same issue using an old verison of Parallels and synergy (Keyboard/mouse sharing application)
It does seem like some of the changes are working - when I set the screen to 3x size it got about 10% larger.. maybe 20%, no way in heck it was 3X anything...
I tried adding 'forced' but the documentation is weak here, it says add that to the end, but is that: , forced or ' forced' or just 'normal3xforced' or I tried normal3x:forced as well..
And it doesn't popup a message saying "bad configuration: Don't know what you mean by forcedUpYour...." so it apparently doesn't matter WHAT you put in the config file, and there is no way to figure it out...
I'm assuming the basic idea here is to download the source code and look through that to see what options are supported, and how you add 'forced' to the output?
So there is no way to know if it is seeing a bad char in the file and blowing off the rest of the file or not...
The source is downloading, so I guess the answer is to look through it and see if I can figure it out...
It should be trivial to add a nX larger screen size (2x is 2xs2 pixels in output drawn for each source pixel, 3x is three... 4 is 4 (I'll need at least 4X maybe 5X, as I'm looking at 3860 in the width, and some of these games are something like 480 as the max x or y size..)
All of the 'Window' options are greyed out as well..
Sigh, so far nothing listed here is working.. Except I was able to find the config file finally.
Reply 14 of 15, by xcomcmdr
It's "hq2x forced" for example.
