First post, by jonmell
Hi - have been running DOSBOX 0.74-3-3 just fine on my MacBook Air M1 / Apple Silicon. Now every time I try to Option-Enter or put fullscreen=true in preferences DOSBOX just quits. No dialog box / error message / nothing in the console as far as I can see.
The only thing I can think of is I recently upgraded to Monteray 12.4 (from 12.3). Anyone else seen this / have any suggestions?
I have posted my preferences file below but also renamed it and ran DOSBOX to create a vanilla one and I had exactly the same issue
# This is the configuration file for DOSBox 0.74-3-3. (Please use the latest version of DOSBox) # Lines starting with a # are co […]
# Lines starting with a # are comment lines and are ignored by DOSBox.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
# fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
# fullresolution: What resolution to use for fullscreen: original, desktop or fixed size (e.g. 1024x768).
# Using your monitor's native resolution (desktop) with aspect=true might give the best results.
# If you end up with small window on a large screen, try an output different from surface.
# On Windows 10 with display scaling (Scale and layout) set to a value above 100%, it is recommended
# to use a lower full/windowresolution, in order to avoid window size problems.
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
# (output=surface does not!)
# output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb.
# autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
# sensitivity: Mouse sensitivity.
# waitonerror: Wait before closing the console if dosbox has an error.
# priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
# pause is only valid for the second entry.
# Possible values: lowest, lower, normal, higher, highest, pause.
# mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the defaul value.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=opengl
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74-3-3.map
usescancodes=true
[dosbox]
# language: Select another language file.
# machine: The type of machine DOSBox tries to emulate.
# Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
# captures: Directory where things like wave, midi, screenshot get captured.
# memsize: Amount of memory DOSBox has in megabytes.
# This value is best left at its default to avoid problems with some games,
# though few games might require a higher value.
# There is generally no speed advantage when raising this value.
language=
machine=svga_s3
captures=capture
memsize=16
[render]
# frameskip: How many frames DOSBox skips before drawing one.
# aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!
# scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,
# then the scaler will be used even if the result might not be desired.
# To fit a scaler in the resolution used at full screen may require a border or side bars,
# to fill the screen entirely, depending on your hardware, a different scaler/fullresolution might work.
# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core: CPU Core used in emulation. auto will switch to dynamic if available and
# appropriate.
# Possible values: auto, dynamic, normal, simple.
# cputype: CPU Type used in emulation. auto is the fastest choice.
# Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
# cycles: Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# Cycles can be set in 3 ways:
# 'auto' tries to guess what a game needs.
# It usually works, but can fail for certain games.
# 'fixed #number' will set a fixed amount of cycles. This is what you usually
# need if 'auto' fails. (Example: fixed 4000).
# 'max' will allocate as much cycles as your computer is able to
# handle.
# Possible values: auto, fixed, max.
# cycleup: Amount of cycles to decrease/increase with keycombos.(CTRL-F11/CTRL-F12)
# cycledown: Setting it lower than 100 will be a percentage.
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
# nosound: Enable silent mode, sound is still emulated though.
# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
# Possible values: 1024, 2048, 4096, 8192, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=44100
blocksize=1024
prebuffer=25
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use
# (find the id with mixer/listmidi).
# Or in the case of coreaudio, you can specify a soundfont here.
# See the README/Manual for more details.
mpu401 = intelligent
mpubase = 0
mididevice = coremidi
midiconfig = 0
samplerate = 44100
mpuirq = -1
mt32.romdir = ~/DOSBOX
mt32.model = auto
[sblaster]
# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
# sbbase: The IO address of the soundblaster.
# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
# irq: The IRQ number of the soundblaster.
# Possible values: 7, 5, 3, 9, 10, 11, 12.
# dma: The DMA number of the soundblaster.
# Possible values: 1, 5, 0, 3, 6, 7.
# hdma: The High DMA number of the soundblaster.
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
# Possible values: auto, cms, opl2, dualopl2, opl3, none.
# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
# Possible values: default, compat, fast.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
# pcrate: Sample rate of the PC-Speaker sound generation.
# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
# Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. Can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
# serial1: set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq (optional).
# for directserial: realport (required), rxdelay (optional).
# (realport:COM1 realport:ttyS0).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
# Possible values: dummy, disabled, modem, nullmodem, directserial.
# serial2: see serial1
# serial3: see serial1
# serial4: see serial1
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms: Enable XMS support.
# ems: Enable EMS support.
# umb: Enable UMB support.
# keyboardlayout: Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
Mount c ~/DOSBOX
C:
#imgmount d "trek2/stjr1.dat" -t iso -fs iso
#imgmount d "trekcd/trek.cfg" -t iso -fs iso
PATH C:\WINDOWS;c:\tc\;c:\tc\bin
SET TEMP=C:\WINDOWS\TEMP
Reply 1 of 22, by TactikalKitty
Not sure if this will help, but M1 Macs in general have issues with displaying content in Fullscreen from applications that are not M1 Silicon optimized. I believe it has to deal with the way Apple now uses Dynamic Scaling. DosBox has this issue. This also broke Elder Scrolls Online as well. You have to run that game in Windowed Mode for instance otherwise it will load but you will be unable to provide any kind of input with a mouse.
Reply 2 of 22, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
you could try this build I did (I'm also the one who created the last release version) https://www.dropbox.com/s/kbrf5elbcu66kst/Dos … apshot.dmg?dl=0
This is using SDL2 via SDL12compat
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 22, by rodbrites
I got something here.
It is almost a full screen...
fullresolution=1920x1080
output=overlay
aspect=true
scaler=normal3x
Reply 6 of 22, by rodbrites
jonmell wrote on 2022-05-28, 14:31:
Hi - have been running DOSBOX 0.74-3-3 just fine on my MacBook Air M1 / Apple Silicon. Now every time I try to Option-Enter or p […]
[sdl]
fullscreen=false
fulldouble=false
output=opengl
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# appropriate.
# handle.
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=25
[midi]
mpubase = 0
midiconfig = 0
samplerate = 44100
mpuirq = -1
mt32.model = auto
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
Mount c ~/DOSBOX
C:
Hey! Got something here:
output=overlay
aspect=true
scaler=normal3x
Reply 7 of 22, by Dominus
DOSBox Moderator
Dominus wrote on 2023-01-04, 15:08:
Thanks for testing. Seems I need to go over my build scripts ;(
Took a while but I fixed my build. Problem was that I use a tool that puts all the required libraries in a subfolder and points the binary at it. The SDL12-compat library needs the SDL2 library but doesn't link to it, so the tool didn't add it to the libraries folder.
Reply 8 of 22, by ctelendil
rodbrites wrote on 2023-01-04, 15:26:
output=overlay
aspect=true
scaler=normal3x
[/quote]
Thank you so much rodbrites!
This fix also helped me. I've been running Dosbox 0.74-3-1 on my Macbook Pro for years, but this week I got a new Macbook M2 running Ventura.
When I hit opt-R to go full screen, the dosbox window stayed the same size but the rest of my screen went black.
The rodbrites build fixed that error. I'm on an Apple M2 pro running OS 13.0. Tested with the full screen with Oregon Trail, Dune 2, and Heroes of Might & Magic. All good.
Reply 9 of 22, by Burrito78
Hi,
i'm running 0.74-3-3 on a M2 mini (2023) macOS Ventura 13.4 (22F66). Deleted my conf file for vanilla settings. When hitting Opt+Enter the DOSBox window just closes without any error message.
Thanks
Sound Blaster: From best to worst
Member of DOSBox Staging
Reply 13 of 22, by traderhut
SVN version doesn't support using a shift key (it appears to be reading the Mac's shift status directly - I had the same issue using an old verison of Parallels and synergy (Keyboard/mouse sharing application)
It does seem like some of the changes are working - when I set the screen to 3x size it got about 10% larger.. maybe 20%, no way in heck it was 3X anything...
I tried adding 'forced' but the documentation is weak here, it says add that to the end, but is that: , forced or ' forced' or just 'normal3xforced' or I tried normal3x:forced as well..
And it doesn't popup a message saying "bad configuration: Don't know what you mean by forcedUpYour...." so it apparently doesn't matter WHAT you put in the config file, and there is no way to figure it out...
I'm assuming the basic idea here is to download the source code and look through that to see what options are supported, and how you add 'forced' to the output?
So there is no way to know if it is seeing a bad char in the file and blowing off the rest of the file or not...
The source is downloading, so I guess the answer is to look through it and see if I can figure it out...
It should be trivial to add a nX larger screen size (2x is 2xs2 pixels in output drawn for each source pixel, 3x is three... 4 is 4 (I'll need at least 4X maybe 5X, as I'm looking at 3860 in the width, and some of these games are something like 480 as the max x or y size..)
All of the 'Window' options are greyed out as well..
Sigh, so far nothing listed here is working.. Except I was able to find the config file finally.
Reply 14 of 22, by xcomcmdr
It's "hq2x forced" for example.
Reply 16 of 22, by LifesaBeach
Dominus wrote on 2023-06-05, 10:52:
Curiously the x86 arch is faster 😉
(Right click on the app and choose that)
Hi Dominus, I am trying to run your build on my MacBook Air M1 running macOS Tahoe 26.5.1 (25F80) and this is what I get:
Translated Report (Full Report Below)
Process: dosbox [50659]
Path: /Applications/DOSBoxSVN.app/Contents/MacOS/dosbox
Identifier: com.dosbox.dosbox
Version: SVN (SVN)
Code Type: ARM-64 (Native)
Role: Default
Parent Process: launchd [1]
Coalition: com.dosbox.dosbox [11370]
User ID: 501
Date/Time: 2026-07-16 10:13:48.3099 +0200
Launch Time: 2026-07-16 10:13:48.2797 +0200
Hardware Model: MacBookAir10,1
OS Version: macOS 26.5.1 (25F80)
Release Type: User
Crash Reporter Key: 345D2256-A381-688F-8812-6E42D76333F3
Incident Identifier: 23AFEABF-EB3E-42EB-B8E1-A23B989F1095
Sleep/Wake UUID: A3F63956-007C-40DE-AA42-7435B81C414C
Time Awake Since Boot: 530000 seconds
Time Since Wake: 89972 seconds
System Integrity Protection: enabled
Triggered by Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace DYLD, Code 1, Library missing
Library not loaded: /opt/arm64/*/libSDL_sound-1.0.1.dylib
Referenced from: <302BD57D-90CC-3CB7-9BA6-708B36F9894D> /Applications/DOSBoxSVN.app/Contents/MacOS/dosbox
Reason: tried: '/opt/arm64/*/libSDL_sound-1.0.1.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/opt/arm64/*/libSDL_sound-1.0.1.dylib' (no such file), '/opt/arm64/*/libSDL_sound-1.0.1.dylib' (no such file), '/usr/lib/libSDL_sound-1.0.1.dylib' (no such file, not in dyld cache)
(terminated at launch; ignore backtrace)
Dyld Error Message:
1
Thread 0 Crashed:
0 dyld 0x18cdb5b84 __abort_with_payload + 8
1 dyld 0x18ce431fc abort_with_payload_wrapper_internal + 104
2 dyld 0x18ce43230 abort_with_payload + 16
3 dyld 0x18cdd5504 dyld4::halt(char const*, dyld4::StructuredError const*) + 312
4 dyld 0x18cdd1718 dyld4::prepare(dyld4::APIs&, mach_o::UnsafeHeader const*) + 4784
5 dyld 0x18cdd044c dyld4::start(dyld4::KernelArgs*, void*, void*, unsigned long long)::$_1::operator()() const + 320
6 dyld 0x18cdcfda8 start + 6904
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000006 x1: 0x0000000000000001 x2: 0x000000016b3da420 x3: 0x000000000000006e
x4: 0x000000016b3da020 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000000
x8: 0x0000000000000020 x9: 0x148559b67a34001d x10: 0x00000001f905bf18 x11: 0x00000001f9078140
x12: 0x0000000000020000 x13: 0x000000018cdb49c0 x14: 0x0000000000000001 x15: 0x0000000000000000
x16: 0x0000000000000209 x17: 0x000000016b3d9e50 x18: 0x0000000000000000 x19: 0x0000000000000000
Show last 182 lines
   x20: 0x000000016b3da020  x21: 0x000000000000006e  x22: 0x000000016b3da420  x23: 0x0000000000000001
x24: 0x0000000000000006 x25: 0x0000000000000000 x26: 0x000000001f070004 x27: 0x0000000000000003
x28: 0x000000018cdb0000 fp: 0x000000016b3d9ff0 lr: 0x000000018ce431fc
sp: 0x000000016b3d9fb0 pc: 0x000000018cdb5b84 cpsr: 0x80001000
far: 0x0000000000000000 esr: 0x56000080 (Syscall)
Binary Images:
0x104a24000 - 0x104c1ffff com.dosbox.dosbox (SVN) <302bd57d-90cc-3cb7-9ba6-708b36f9894d> /Applications/DOSBoxSVN.app/Contents/MacOS/dosbox
0x18cdb0000 - 0x18ce56217 dyld (*) <a237ef81-b68b-37ba-a165-92c965529534> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=576.0M resident=0K(0%) swapped_out_or_unallocated=576.0M(100%)
Writable regions: Total=53.3M written=128K(0%) resident=128K(0%) swapped_out=0K(0%) unallocated=53.1M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
STACK GUARD 56.0M 1
Stack 8176K 1
__AUTH_CONST 22K 1
__DATA 45.3M 3
__DATA_CONST 41K 2
__DATA_DIRTY 14K 1
__LINKEDIT 573.3M 2
__TEXT 2700K 2
__TPRO_CONST 128K 1
dyld private memory 16K 1
page table in kernel 128K 1
TOTAL 685.6M 16
Full Report
{"app_name":"dosbox","timestamp":"2026-07-16 10:13:48.00 +0200","app_version":"SVN","slice_uuid":"302bd57d-90cc-3cb7-9ba6-708b36f9894d","build_version":"SVN","platform":1,"bundleID":"com.dosbox.dosbox","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 26.5.1 (25F80)","roots_installed":0,"name":"dosbox","incident_id":"23AFEABF-EB3E-42EB-B8E1-A23B989F1095"}
"uptime" : 530000,
"procRole" : "Default",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookAir10,1",
"coalitionID" : 11370,
"osVersion" : {
"train" : "macOS 26.5.1",
"build" : "25F80",
"releaseType" : "User"
"captureTime" : "2026-07-16 10:13:48.3099 +0200",
"codeSigningMonitor" : 1,
"incident" : "23AFEABF-EB3E-42EB-B8E1-A23B989F1095",
"pid" : 50659,
"translated" : false,
"cpuType" : "ARM-64",
"procLaunch" : "2026-07-16 10:13:48.2797 +0200",
"procStartAbsTime" : 12875587356147,
"procExitAbsTime" : 12875588055982,
"procName" : "dosbox",
"procPath" : "\/Applications\/DOSBoxSVN.app\/Contents\/MacOS\/dosbox",
"bundleInfo" : {"CFBundleShortVersionString":"SVN","CFBundleVersion":"SVN","CFBundleIdentifier":"com.dosbox.dosbox"},
"storeInfo" : {"deviceIdentifierForVendor":"D79433EB-2100-5211-BC13-C24D32E1336D","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.dosbox.dosbox",
"crashReporterKey" : "345D2256-A381-688F-8812-6E42D76333F3",
"appleIntelligenceStatus" : {"reasons":["selectedLanguageDoesNotMatchSelectedSiriLanguageInfo(system: en, siri: fr)","selectedLanguageDoesNotMatchSelectedSiriLanguage"],"state":"unavailable"},
"developerMode" : 1,
"bootProgressRegister" : "0x2f000000",
"codeSigningID" : "com.dosbox.dosbox",
"codeSigningTeamID" : "5PRK96AWD5",
"codeSigningFlags" : 570491393,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"codeSigningAuxiliaryInfo" : 0,
"instructionByteStream" : {"beforePC":"vAAAADgBAABwAAAAAAEAAGgAAAAYAQAASAEAAGwBAAAwQYDSARAA1A==","atPC":"AwEAVH8jA9X9e7+p\/QMAkYX0\/5e\/AwCR\/XvBqP8PX9bAA1\/WEC2A0g=="},
"bootSessionUUID" : "807DA56E-32AE-40E2-910E-37292B3F76B6",
"wakeTime" : 89972,
"fatalDyldError" : 1,
"sleepWakeUUID" : "A3F63956-007C-40DE-AA42-7435B81C414C",
"sip" : "enabled",
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
"termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: \/opt\/arm64\/*\/libSDL_sound-1.0.1.dylib","Referenced from: <302BD57D-90CC-3CB7-9BA6-708B36F9894D> \/Applications\/DOSBoxSVN.app\/Contents\/MacOS\/dosbox","Reason: tried: '\/opt\/arm64\/*\/libSDL_sound-1.0.1.dylib' (no such file), '\/System\/Volumes\/Preboot\/Cryptexes\/OS\/opt\/arm64\/*\/libSDL_sound-1.0.1.dylib' (no such file), '\/opt\/arm64\/*\/libSDL_sound-1.0.1.dylib' (no such file), '\/usr\/lib\/libSDL_sound-1.0.1.dylib' (no such file, not in dyld cache)"]},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":4948712,"threadState":{"x":[{"value":6},{"value":1},{"value":6094169120},{"value":110},{"value":6094168096},{"value":0},{"value":0},{"value":0},{"value":32},{"value":1478686692930224157},{"value":8472870680,"symbolLocation":15832,"symbol":"lsl::sPoolBytes"},{"value":8472985920},{"value":131072},{"value":6658148800,"symbolLocation":0,"symbol":"_dyld_start"},{"value":1},{"value":0},{"value":521},{"value":6094167632},{"value":0},{"value":0},{"value":6094168096},{"value":110},{"value":6094169120},{"value":1},{"value":6},{"value":0},{"value":520552452},{"value":3},{"value":6658129920}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6658732540},"cpsr":{"value":2147487744},"fp":{"value":6094168048},"sp":{"value":6094167984},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6658153348,"matchesCrashFrame":1},"far":{"value":0}},"frames":[{"imageOffset":23428,"symbol":"__abort_with_payload","symbolLocation":8,"imageIndex":1},{"imageOffset":602620,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":104,"imageIndex":1},{"imageOffset":602672,"symbol":"abort_with_payload","symbolLocation":16,"imageIndex":1},{"imageOffset":152836,"symbol":"dyld4::halt(char const*, dyld4::StructuredError const*)","symbolLocation":312,"imageIndex":1},{"imageOffset":136984,"symbol":"dyld4::prepare(dyld4::APIs&, mach_o::UnsafeHeader const*)","symbolLocation":4784,"imageIndex":1},{"imageOffset":132172,"symbol":"dyld4::start(dyld4::KernelArgs*, void*, void*, unsigned long long)::$_1::operator()() const","symbolLocation":320,"imageIndex":1},{"imageOffset":130472,"symbol":"start","symbolLocation":6904,"imageIndex":1}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 4372709376,
"CFBundleShortVersionString" : "SVN",
"CFBundleIdentifier" : "com.dosbox.dosbox",
"size" : 2080768,
"uuid" : "302bd57d-90cc-3cb7-9ba6-708b36f9894d",
"path" : "\/Applications\/DOSBoxSVN.app\/Contents\/MacOS\/dosbox",
"name" : "dosbox",
"CFBundleVersion" : "SVN"
"source" : "P",
"arch" : "arm64e",
"base" : 6658129920,
"size" : 680472,
"uuid" : "a237ef81-b68b-37ba-a165-92c965529534",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"sharedCache" : {
"base" : 6656999424,
"size" : 5990596608,
"uuid" : "ff7119a7-f64d-305d-8135-7e6eb1c207d1"
"vmSummary" : "ReadOnly portion of Libraries: Total=576.0M resident=0K(0%) swapped_out_or_unallocated=576.0M(100%)\nWritable regions: Total=53.3M written=128K(0%) resident=128K(0%) swapped_out=0K(0%) unallocated=53.1M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8176K 1 \n__AUTH_CONST 22K 1 \n__DATA 45.3M 3 \n__DATA_CONST 41K 2 \n__DATA_DIRTY 14K 1 \n__LINKEDIT 573.3M 2 \n__TEXT 2700K 2 \n__TPRO_CONST 128K 1 \ndyld private memory 16K 1 \npage table in kernel 128K 1 \n=========== ======= ======= \nTOTAL 685.6M 16 \n",
"legacyInfo" : {
"threadTriggered" : {
"logWritingSignature" : "4a3b85e6f1fe8c91b2c82b1a4bab3ce18e9a4170",
"bug_type" : "309",
"roots_installed" : 0,
"trmStatus" : 1,
"trialInfo" : {
"rollouts" : [
"rolloutId" : "64628732bf2f5257dedc8988",
"factorPackIds" : [
"deploymentId" : 240000001
"rolloutId" : "67d07cd6a7affa169ae21f45",
"factorPackIds" : [
"deploymentId" : 240000002
"experiments" : [
Model: MacBookAir10,1, BootROM 18000.120.36, proc 8:4:4:0 processors, 8 GB, SMC
Graphics: Apple M1, Apple M1, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Display: CR320HD, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online
Memory Module: LPDDR4, Micron
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Dec 18 2025 18:13:50 version 18.110.6.0.7.8.189 FWID 01-2a12ab25
IO80211_driverkit-1561.3 "IO80211_driverkit-1561.3" Apr 18 2026 17:42:26
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Thunderbolt Bus: MacBook Air, Apple Inc.
I also could not see any right click option to run the x86 arch.
Are you still able to run your build in 2026?
Cheers
Reply 17 of 22, by jmarsh
You are missing the libSDL_Sound library.
Reply 18 of 22, by LifesaBeach
jmarsh wrote on 2026-07-16, 08:55:
Thank you! I installed the library using Homebrew but I still get an error message:
Process: dosbox [53231]
Version: SVN (SVN)
Role: Default
User ID: 501
Date/Time: 2026-07-16 11:17:53.6431 +0200
Launch Time: 2026-07-16 11:17:53.6162 +0200
Release Type: User
Incident Identifier: BFF19464-952B-4BF8-B573-95C1D0CB08A5
Time Awake Since Boot: 540000 seconds
Time Since Wake: 93817 seconds
Dyld Error Message:
1
Thread 0 Crashed:
x0: 0x0000000000000006 x1: 0x0000000000000001 x2: 0x000000016f4ea420 x3: 0x000000000000006e
x4: 0x000000016f4ea020 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000000
x8: 0x0000000000000020 x9: 0xd3d69d03541e009a x10: 0x00000001f905bf18 x11: 0x00000001f9078140
x16: 0x0000000000000209 x17: 0x000000016f4e9e50 x18: 0x0000000000000000 x19: 0x0000000000000000
Show last 169 lines
   x20: 0x000000016f4ea020  x21: 0x000000000000006e  x22: 0x000000016f4ea420  x23: 0x0000000000000001
x24: 0x0000000000000006 x25: 0x0000000000000000 x26: 0x000000001f070004 x27: 0x0000000000000002
x28: 0x000000018cdb0000 fp: 0x000000016f4e9ff0 lr: 0x000000018ce431fc
sp: 0x000000016f4e9fb0 pc: 0x000000018cdb5b84 cpsr: 0x80001000
Binary Images:
0x100914000 - 0x100b0ffff com.dosbox.dosbox (SVN) <302bd57d-90cc-3cb7-9ba6-708b36f9894d> /Applications/DOSBoxSVN.app/Contents/MacOS/dosbox
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
VIRTUAL REGION
STACK GUARD 56.0M 1
Stack 8176K 1
__AUTH_CONST 22K 1
__DATA 45.3M 3
__DATA_CONST 41K 2
__DATA_DIRTY 14K 1
__LINKEDIT 573.3M 2
__TEXT 2700K 2
__TPRO_CONST 128K 1
TOTAL 685.6M 16
Full Report
{"app_name":"dosbox","timestamp":"2026-07-16 11:17:53.00 +0200","app_version":"SVN","slice_uuid":"302bd57d-90cc-3cb7-9ba6-708b36f9894d","build_version":"SVN","platform":1,"bundleID":"com.dosbox.dosbox","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 26.5.1 (25F80)","roots_installed":0,"name":"dosbox","incident_id":"BFF19464-952B-4BF8-B573-95C1D0CB08A5"}
"uptime" : 540000,
"version" : 2,
"userID" : 501,
"osVersion" : {
"build" : "25F80",
"captureTime" : "2026-07-16 11:17:53.6431 +0200",
"incident" : "BFF19464-952B-4BF8-B573-95C1D0CB08A5",
"pid" : 53231,
"procLaunch" : "2026-07-16 11:17:53.6162 +0200",
"procStartAbsTime" : 12967872175761,
"procExitAbsTime" : 12967872786310,
"parentPid" : 1,
"wakeTime" : 93817,
"sip" : "enabled",
"threads" : [{"triggered":true,"id":4990586,"threadState":{"x":[{"value":6},{"value":1},{"value":6162392096},{"value":110},{"value":6162391072},{"value":0},{"value":0},{"value":0},{"value":32},{"value":15264560624640589978},{"value":8472870680,"symbolLocation":15832,"symbol":"lsl::sPoolBytes"},{"value":8472985920},{"value":131072},{"value":6658148800,"symbolLocation":0,"symbol":"_dyld_start"},{"value":1},{"value":0},{"value":521},{"value":6162390608},{"value":0},{"value":0},{"value":6162391072},{"value":110},{"value":6162392096},{"value":1},{"value":6},{"value":0},{"value":520552452},{"value":2},{"value":6658129920}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6658732540},"cpsr":{"value":2147487744},"fp":{"value":6162391024},"sp":{"value":6162390960},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6658153348,"matchesCrashFrame":1},"far":{"value":0}},"frames":[{"imageOffset":23428,"symbol":"__abort_with_payload","symbolLocation":8,"imageIndex":1},{"imageOffset":602620,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":104,"imageIndex":1},{"imageOffset":602672,"symbol":"abort_with_payload","symbolLocation":16,"imageIndex":1},{"imageOffset":152836,"symbol":"dyld4::halt(char const*, dyld4::StructuredError const*)","symbolLocation":312,"imageIndex":1},{"imageOffset":136984,"symbol":"dyld4::prepare(dyld4::APIs&, mach_o::UnsafeHeader const*)","symbolLocation":4784,"imageIndex":1},{"imageOffset":132172,"symbol":"dyld4::start(dyld4::KernelArgs*, void*, void*, unsigned long long)::$_1::operator()() const","symbolLocation":320,"imageIndex":1},{"imageOffset":130472,"symbol":"start","symbolLocation":6904,"imageIndex":1}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 4304486400,
"size" : 2080768,
"name" : "dosbox",
"source" : "P",
"arch" : "arm64e",
"size" : 680472,
"name" : "dyld"
"size" : 0,
"source" : "A",
"base" : 0,
"sharedCache" : {
"legacyInfo" : {
"bug_type" : "309",
"trmStatus" : 1,
"trialInfo" : {
"rollouts" : [
"factorPackIds" : [
"factorPackIds" : [
"experiments" : [
Reply 19 of 22, by jmarsh
Apparently that was the wrong library (probably the wrong architecture) because it's the same error message.
