First post, by Paolo_R
DOSBOX defaults to an 80 x 25 text screen. Is it possible to change this, say, to 80 x 40, thus emulating the MODE CON command?
Yes. The Freedos mode command works:
http://www.ibiblio.org/pub/micro/pc-stuff/fre … s/mode/modecon/
I didn't bother to check the DOS one, but I'd wager it does as well.
-Frob
I've no doubt that FreeDOS has a mode command. My question related to DosBOX.
you can use the utility of freedos INSIDE DOSBox
Water flows down the stream
OK, I see what you mean. From what you suggest, I deduce that there is no such facility in DosBOX.
Thanks
there is no need as external utilites work fine
