Screen Lines/Cols
First post, by Paolo_R
DOSBOX defaults to an 80 x 25 text screen. Is it possible to change this, say, to 80 x 40, thus emulating the MODE CON command?
Reply 2 of 5, by Paolo_R
I've no doubt that FreeDOS has a mode command. My question related to DosBOX.
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
you can use the utility of freedos INSIDE DOSBox
Water flows down the stream
Reply 4 of 5, by Paolo_R
OK, I see what you mean. From what you suggest, I deduce that there is no such facility in DosBOX.
Thanks
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
there is no need as external utilites work fine
