First post, by Fexel
Hello!
I managed to install Win95c into Dosbox SVN Daum 0.74.
I made it via the guide here on vogons. Creating Disk Image and Installation process worked. An Issue at the begin of the win setup made me a bit agitaed. It said "theres not enough ram to test hd" I set conf to 6x memsize. So i dont know why this message came up. Anyway, i started setup. Worked.
First Start with Win95 gave me an Error. Windows-Security Error. Please reboot your Computer
My .conf file is attached to this post.
For the audience: It was no problem to start win95 in save-mode. So i think, its a driver issue but i cant find the problematic one.. maybe someone can help me with that. Would be very kind!
Thank u.
I found the clue. I had to deactivate isapnpbios. But Problems still there.. Now i can startup Win95 but the configuration process crashes it. I get a bluescreen. Hm here are the message:
